My outside temperature sensor has been acting crazy since a few days.
it's showing 40-50 degrees but it's over 70-80!
Where is the sensor ? Anyone else had that problem ? What should I check
thanks
I had that problem in my '05 V50 and the issue was the sensor itself needed to be replaced. It's located in the driver's side mirror housing.
06/07 are notorious for the door harness connector issues. I would investigate whether ur door harness connectors have been services with the updated connector and/or pursue a possible harness issue with the sensor/DDM.
There are numerous threads on this issue which have all the info you need.
