1 - 2 of 2 Posts
Discussion Starter #1
I've searched and read, and all things likely point to the ABS module, but I thought I would get some input from other members.
I have a 2002 V70 N/A. "Transmission Service Required" light is on, and won't stay off - if I clear the codes, the light is back on within 100ft of driving.
The ECM has code PO722 stored (I understand this code is an indicator that codes are stored in other modules)
The TCM has code PO722 - Output Speed Sensor No Signal.
Before I pull the ABS module and take it to Xemodex, I wondered if there was a test I could do (resistance?) for the output speed sensor?
Thanks in advance for any input.
Discussion Starter #2 (Edited)
I guess I'm the only one reading, so for my own conclusion:
I popped the air box for better access to remove the ABS module. As soon as I lift it out, wouldn't you know what I find...
1 - 2 of 2 Posts
