1 - 9 of 9 Posts
I swear, with the Volvo these past few days and maybe weeks, its just been one ****ing thing after the next.
First, I went to put new rear brakes on. Rotors were frozen/rusted to the hubs. When I finally busted those off, I find that 3/4 of my parking brake shoes are AWOL (what. the. ****!?) great. Everything looks pretty rusty so I just ignore that make a note and label not to use the handbrake. I also note that my rear shocks and springs are nearing the end of their lives.
Next. A day or 2 after the brakes, the driveshaft support fails in a pretty spectacular way, causing me to nearly send the car off the road, right before it grinds to a halt shaking like a wet dog in a freezer. Okay...common Volvo thing...I'll have the local specialists take care of it.
Yesterday. I had left the car at Import Specialists Inc. last week and told them not to worry about getting me the car quickly...I don't want to look at it. They call and tell me the car is ready and that I need to get it. Okay, $181.15 later (1 supt. bushing, 1 bearing, 1 spring, 1 washer +labor) and I'm on my way to school. Within a few miles of leaving the shop, THE FREAKIN WINDSHIELD CRACKS. Stone chip, it looks like. Greeeaaat. Its not in my line of vision, so I'll just pretend not to notice for a while....
That night, on the way home, I notice that the heater has given up on the heating business. I can't see the temp guage, but I'm sure it was pegged at this point from a loss of coolant. I figure that my heater control valve is acting up again and keep going, stopping only when my blower motor stops working and I have to pull over and fiddle with the fuse (ARRRRGGGG) The motor sounds like a blender full of ball bearings, but at least it works. Can't wait to tackle THAT job....
Today. I CAN see the temp guage, and I notice a few miles from school that its almost in the red. Well **** me... Thanks to the cold, I manage to get to school without fully overheating. The car is BONE DRY coolant wise, and the left side of the rad has shot coolant all over everything. Its been leaking for a while...now its fully busted. Greeeeaaaat.
I call my dad, who comes to the rescue in his 1986 Nissan Pulsar (HIS '86 never breaks down spectacularly...good old Nissans) and many gallons of water. We fill er up and limp the car home that way.
Upon getting home, I roll up the sleeeves and rip everything out. And now here I am venting. The end result? Pics below:
Here we have a junk radiator, and a fan shroud ripped out of the Volvo, along with rolls of the home mechanic's 2 most useful tools.
Datsun keeping guard over the parts I need to keep, and the small bit of coolant I actually managed to catch. Note the gross brownness of coolant that isn't much more than a year old. I think I'd better flush it.
Note that in the background I have a Datsun that is in fantastic shape and works perfectly, right down to the air conditioning, but no, that one sits most of the time and I drive a rusty turdbox that fails once a week instead. gawrsh I'm smrt.
In case you were wondering, here's what a Volvo B230F with no way to cool itself looks like:
Note large puddles around the car. Thats me hosing off the driveway so I don't kill all the neighborhood critters with spilled coolant.
And here's what this little adventure is going to cost me:
That said $175 for a all-copper 3-row is cheap. Ah well. Time to place another order with the fine folks at FCP Groton.
Sorry about length and huge pics.
Looks like you had a rough time with the Wagon. Yep, engine flush is in order.. You also want to check that coolant to see if oil has pooled up in it. ( you did say it was brown) After you get that checked out check the expan tank to see if it is brittle and has oil deposits in it too. ( I had an 81 245 that did this. )
There are two different hoses that are under the intake plenum that goes into the fire wall, You may want to change these out as well as your radiator hoses. ( not knowing how long it has been senes these have been changed ) You will see a pipe that comes off the water pump on the right hand side, follow that pipe around the right side of the engine to the back and you will see that there is a hose that goes into the fire wall as well. Replace all of them. Soon as you put in a new radiator ect, you will find that they may fail. Best be safe than sorry.
Just some tips that may save you a headache. ( Happend to me twice 1 my 242 gt and the 81 245 )
Re: (AndytheNissanBoy)
Just wondering if you know that your battery has the terminals on the wrong sides. 240 battery should have the positive on the other side, so it's inboard of the fender. It's generally like that, I assume because if the battery were to come loose and shift, you don't want the positive terminal bumping the fender.
I was just out fiddling with my taillight wiring.
Both of my ground wires weren't connected to anything but a sheet metal screw and a blob of rust :| I did some re-grounding and now I think my bulb failed light won't come on every time I brake. Sweeet.
i know how you feel. it feels like that with my car too, you fix something and the area around it gets crushed by some idiot in a minivan. well i hope you get things all worked out, and people...... pressure wash your engines. its not hard and it makes it easier to see when your rear main engine seal fails (although im sure thats pretty much obvious) or some similar disaster.
1 - 9 of 9 Posts
