original post:
http://forums.swedespeed.com/zerothread?id=115469
Custom Oil Temp/Haldex Temp/Photo Slideshow Gauge in the making! Using...PICAXE uController and 4D system's OLED (96x64)
Here's what I have come up with so far:
The OLED display needs to be powered down properly so I've programmed the PICAXE via an interrupt to initiate a power-down sequence when the ACC line goes low. When ACC line goes low, the PICAXE has power for 7 seconds (using a cap, relay and some resistors) and in this time it initiates the power-down sequence to the OLED.
You can see the pics and vid of the project working without any thermo sensing device. In the video you can see that the gauge alternates between a temperature screen and 1 of 14 random R images (all of which I've snagged from the forum, thanks all!). There is also a random splash screen upon startup!
http://www.caschy.com/coppermi...a.AVI (don't mind the stupid shutter noise or Dancing with the Stars in the background
Next up, trying to find a thermocouple to read oil temp!
