1 - 20 of 21 Posts
Jaguar XFR
ok I admit, I have no clue what I'm doing! (56k entensive)
Is the transmission drain plug in both the GT and MT in the same place? (does that mean I have to take off the left front wheel?) Or am I missing it?<p><BR><BR>
<i>Modified by o2k at 10:30 PM 3-25-2009</i>
First pic is oil <br>on the side of the tranny will be a 18mm IIRC <br>remove that bolt and the tranny fluid will drain out
here that bolt circled is the tranny fluid drain hole <br>Same on all cars 850,S,V,C70,S60,V70 <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <br><IMG SRC="http://i267.photobucket.com/albums/ii298/R410a/P1040131-1.jpg" BORDER="0">
Can you get a pic from the other side ? <p>Then I can circle the exact one for you <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Also next time change your crush washer when you change your oil <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
uh the drain plug for a manual is on the drivers side if you take the wheel off it is right in front of you on the bottom side of the transmission. <p>The side your pictures are from are of the engine and bevel gear not the transmission. The bevel gear has no drain plug.<br>
Re: (racecarcolin)
"Lifetime fluid" <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Jaguar XFR
Re: ok I admit, I have no clue what I'm doing! (o2k)
Wow. Thanks for all the info!! I'm out right now. I will take more pics when I go back home. I will also try to take pics so we can compose a DIY for the new master list.
best guess on just a drain is between 4-6 since a few quarts do get stuck in the tourque converter.
Re: (03silvers60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>03silvers60</b> »</i></TD></TR><TR><TD CLASS="quote">how many quarts will drain when u remove the drain?</TD></TR></TABLE><p>If you mean Auto Trans Fluid, about 4 qts will drain out. <br>YMMV always check the stick. <br>I like to add about 3 1/2 and then check level while hot.<br>I think Volvo calls for checking the fluid level at at least 70C oil temp.<br>You can get the temp that warm very quickly by power braking the trans at stall speed for about 15-20 seconds.<br>In VIDA you can watch the temp climb rapidly while the trans is at stall speed.<br>Whats harmful is the temp getting excessively hot, thats when the fluid and parts can fail.<br>So I wouldn't power brake it longer than that and thats starting with a cold engine.<br>Cold being 21C or 70F.<p>Edit: Fixed?
OMG someone fix the pics lol oceans typing goes on for ever lol
Re: (Chilled Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Chilled Man</b> »</i></TD></TR><TR><TD CLASS="quote">First pic is oil <br>on the side of the tranny will be a 18mm IIRC <br>remove that bolt and the tranny fluid will drain out </TD></TR></TABLE><br>a 15/16th wrench fits perfectly so 24mm <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>And get two aluminum crush rings when you get your fluid. <br>One for the tranny drain plug, the other for your leaking oil drain plug.<br>They are both the same size crush ring <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Ahh cool the oil drain plug is 17mm <p>I couldnt remeber the tranny one its been awhile since I had to do it.
Jaguar XFR
Discussion Starter · #15 ·
Re: (Chilled Man)
Again, thanks for all the help. Thanks Justin for the pic.. I was actually looking for a larger bolt...didn't realize it was a thinner. As I undid the drain bolt, the whole time I was thinking, "please don't fall in, please don't fall in" next thing I know....Ploop! right into the bucket with trans fluid. Anyway, here are some pics.<p>Drain<br><IMG SRC="http://i674.photobucket.com/albums/vv110/oxidizer2k/S60r%20Underbody/P1040155.jpg" BORDER="0"><p>Fill<br><IMG SRC="http://i674.photobucket.com/albums/vv110/oxidizer2k/S60r%20Underbody/untitled.jpg" BORDER="0">
So this was just a drain and fill, not a flush. I know there was a VS writeup on that somewhere.
Jaguar XFR
Discussion Starter · #17 ·
Re: ok I admit, I have no clue what I'm doing! (BeerEngineer)
Pretty much. I drained it, filled it. Drove around for a bit, repeated it. Not a full flush, but after the second time, fluid looked very clean.
Hmmm...I may go this route as well. Just called the local Volvo dealer and they quoted a $200 price for a full flush. How much did you spend on fluids and total time involved? Trying to figure out if its cheaper to pay someone to do it although I would like to take this on myself.<p>Thanks.<br>BW
Re: ok I admit, I have no clue what I'm doing! (Bdubs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Bdubs</b> »</i></TD></TR><TR><TD CLASS="quote">Hmmm...I may go this route as well. Just called the local Volvo dealer and they quoted a $200 price for a full flush. How much did you spend on fluids and total time involved? Trying to figure out if its cheaper to pay someone to do it although I would like to take this on myself.<p>Thanks.<br>BW</TD></TR></TABLE><p>Fluids aren't cheap, esp. if you go with Volvo fluid and not Mobil 3309. Even that isn't cheap.
i flushed mine from the top cooler hose last weekend, 6.5 came out, new back in, and i am so happy with the results, like a new car, i got it with 55K and now it has 70K and it runs so smooth its amazing what 70 bucks and and hour can do!
1 - 20 of 21 Posts
