Re: (o2k)
The problem is that the "R" headlamps (and pre 2005 HID's) have a built-in microprocessor that communicates back to the ECM via PWM. I am thinking that MAYBE if I disconnect the 'high beam' wire that the lack of a trigger will not throw a code (waiting for a nicer day to find out, that'd be orgasmic if it works), but any other headlamp is just a 'plain Jane' setup with no fancy communication I believe. Long story short, the "high beam" in this car shifts the entire headlamp reflector up and out, and there's a system of 'checks' that not only sense how far the motor to actuate all of this has moved, but how far the reflector itself has moved. I had a post on it, but Snapfish = fail. Scroll to the bottom to see pics (I'll go and try to re-activate them, or take new shots if you REALLY want):
http://forums.swedespeed.com/zerothread?id=95554
Basically, this image (from the above post), from left to right, is of the internal circuitry/motor, gearing to move the reflector, and the case (with the 'check' in front of it to see how much the reflector moved:
This is a post of some progress I had made (I have made further progress since):
http://forums.swedespeed.com/zerothread?id=109093
...this is an image of what is behind the reflector. The case (from the image above) is the larger box on the left, and the whole black 'frame' shifts forward, with the bulb in the middle:
This post has been brought to you by the letter "R" and the number 2.
