1 - 6 of 6 Posts
I'm thinking about getting an oil temp gauge, and was wondering where I would tap the sender? Where is the most accurate place to get a reading? Oh, I know this is the R forum, and I don't have an R, but I have an R bumper, so it's all good.
Kidding, guys on the S60 forum probably wouldn't know...
Thanks
-Cory
Re: Oil Temp Gauge Questions (cmurphy2266)
I used a temp sensor going through the oil drain plug. Basically it replaced the plug with an adapter and the sensor went in that. I don't know how representative of the rest of the oil system, but it seemed to be a simple spot to get to.
I don't have the part number of the plug or anything since I picked it up from the mechanic I use. Sorry.
Re: Oil Temp Gauge Questions (Jeremy7o2)
Quote, originally posted by Jeremy7o2 »
Thanks for the response, do you remember what it cost you?
here you go-http://www.glowshiftdirect.com/Oil-Filter-Sandwich-Adapters.aspx
i found this when i was looking for a place to mount the sending unit on my 960
Re: (sacrifice)
Quote, originally posted by sacrifice »
Thanks, I'll check that out!
1 - 6 of 6 Posts
