1 - 9 of 9 Posts
As my S60 2.0T is about to arrive, I was wondering what synthetic oil & grade to use after the break-in period (about 6k miles/10k km).<p>The mediterranean climate here has very mild winters (2C/37F minimum) and warm (but not desert hot) summers (36C/98 F).<p>Since volvo recommends Castrol, should I go with GTX 10W-30?<br>They also have Mobil 1 0W-40 available here, isnt that a bit too thin for such climate?<p>Thanks!
Re: Oil question (xr0x)
Mobil 1 10/30 all the way.
Magoon, does Mobil send you a monthly check?
Re: (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote">Magoon, does Mobil send you a monthly check?</TD></TR></TABLE><p>I wish. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>As many have pointed out, it's probably the best widely sold synthetic available. Are you a Castrol believer since Volvo says so?
i used your recommendation of syntec blend for my FIRST oil change, and when i get back from OBX in mid-august, i will be switching to mobil 1 10/30 <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: (phuz)
My vote is for Mobil 1 because of its wide availabilty. If Amsoil was widely available, I would probably go with that based on reviews I have read.
so ur saying 10/30?<br>I'm wondering why they only have 0/40 in gas stations here..<br>
Buy the 10/30 Mobil 1. Can't go wrong with that suggestion. And 5/40 wouldn't be thin. It would have a higher VI than the 10/30.<p>0/40 or 5/40 would be okay as well in that climate. <p>Here in Michigan you usually can play with a winter oil and a summer oil. I am going to use Mobil 1 5/30 in the winter and am using GC (German Castrol) 0/30 for the summer. Why you ask???<p>The Castrol Syntec (GC means you have to get it only at Autozone and find the bottles that say made in Germany, hence German Castrol), 0/30 is actually almost a 40 weight oil if you look at the spec's.
1 - 9 of 9 Posts
