its supposed to be there oil actually pushes threw the porus turbo metal
Re: Oil on bottom of turbo (Danhaggis)
Turbo return line (dump tube) seal or the line itself.
Common, ALL (Volvo) turbos need to have either the seal or the line replaced every 80-100K or so and you should worry about it (a little).
You should have it looked at and repaired, (or replaced) although it's not an emergency it should be done
