1 - 2 of 2 Posts
Going to finally fix a coulple oil leaks. The first being the oil pan
The second I am not sure about but i suspect the RMS. Is the RMS easily diagnosed? How can I tell if thats my problem?
In the picture below I also found this hose which looks in bad shape and just waiting to fail. What is this hose? While under the car I found an elctrical connector not connected to anything, just hanging there. This is rught under ther turbo area. When i put my hand in there i also found a 90 degree vacuum elbow just sitting on the frame of the car. Probably been riding along there for a while. I can't suspect it goes to anything because the car runs fine and shows no signs of vacuum or could it be something? I have no check engine light...
That hose is for the turbo. I just replaced mine which was in the same condition. Not sure about the first pic - I hope it's not the RMS! Not sure how to diagnose the RMS.
1 - 2 of 2 Posts
