1 - 2 of 2 Posts
Can anyone speak to where the oil filter is located on the new V60? Is it accessible from the top of the engine, making it easy to use an oil extractor for an oil change?
2018 Volvo V90CC T6
The T5/T6 oil filter is buried at the bottom. You will need to put the Vehicle on a lift or ramps and remove the aero-panel to get access to the oil filter. Also, you require a special tool to remove the filter. There is a very elaborate thread on the XC90 sub-forum explaining a DIY Oil change for our SpA Vehicles.
EDIT: Here you go. https://forums.swedespeed.com/showthread.php?539386-SPA-XC90-DIY-Oil-Change-with-pics
1 - 2 of 2 Posts
