1 - 6 of 6 Posts
· Registered
Re: OIL consumption... (KIM 850)
Quote, originally posted by KIM 850 »
Hi again everyone,
I want your opinion,my engine seems to"eat"the oil!!!I have driven 60000 km from the total repair of the engine.What can be the problem?
thanks.
Total repair.....can you elaborate.
· Registered
Re: OIL consumption... (TurboMoose)
Well,my car was '94 GLT,I bought an engine with unknown kilometres.It looked to be good.A nice evening I had increased the turbo pressure too much,with 4th gear the gauge was over 1,4bar.I was driving all night against other cars,so next morning on my way to work I put 3rd from 4th to accelerate fast and a noise started from the engine.It was like nissan bluebird diesel.When the engine got cold the noise was louder,it was like a"dead"connecting rod.So I decided to disassemble the engine to check and repair.I changed everything except the pistons.I sent the crank and the rods for a check-up,and finally the problem was the oil pump!!!high pressure.Now since then I've changed 4 types of oil.first shell 15w-50, 1litre/1000km,then shell 5w-40 1lt/1000km and a bit more,then motul 300V 15w-50 1lt/1000km,and finally now volvo 15w-40 550gr/1000km.
· Registered
Not installing new pistons was foolish.
You probably have a bad ring now
· Registered
Re: OIL consumption... (JRL)
What exactly do you mean,by saying bad rings?
the pistons were in very good situation,even the piston rings,I changed for better.If it was something from the rings I souldn't have good performance,is that right?
1 - 6 of 6 Posts
