1 - 11 of 11 Posts
I have been running Amsoil 0W-30 for 30kmiles. My last oil change was at 93k and I just turned 96.5kmiles. I just added 3/4 qt to top her off.<br>I run each fresh Amsoil change for 6Kmiles, execute an oil filter change only and install a clean K&N air filter, and then run another 6k. I always check the levels and add as needed. btw, I am averaging 24.3 mpg.<br> <br>I think this is pretty good considering that most of my ride is highspeed highway, and I will admit to driving...assertively. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <br>Is this typical for others with this mileage? Should I have any concerns?<br>Thanks- Scott
Re: Oil consumption (Lightspeed)
IMO, consumption is fine for the mileage and car. I add maybe 1/2 quart between oil changes.
Scott, <p>Mine uses about the same at 103k miles - oil change interval 5k - M1 Extended 10W-30. Same driving pattern as yours. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: Oil consumption (ZenZone)
Same here, ~3/4 of a quart on avg., 5k intervals and ~100k miles.
Re: Oil consumption (S60R1)
I usually do 3-5K between changes, depending largely on how many (if any) trackdays I put on the oil. If I do a track day or lots and lots of really hard driving, I might be down 1/3 to 1/2 quart after 3-5K. With no trackdays and a bit easier driving (usually winter) I'm hardly down at all.
Re: Oil consumption (MagoonR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MagoonR</b> »</i></TD></TR><TR><TD CLASS="quote">IMO, consumption is fine for the mileage and car. I add maybe 1/2 quart between oil changes.</TD></TR></TABLE><p>1 quart every 6-7k for me. <p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Lightspeed</b> »</i></TD></TR><TR><TD CLASS="quote">I have been running Amsoil 0W-30 for 30kmiles. My last oil change was at 93k and I just turned 96.5kmiles. I just added 3/4 qt to top her off.<br>I run each fresh Amsoil change for 6Kmiles, execute an oil filter change only and install a clean K&N air filter, and then run another 6k. I always check the levels and add as needed. btw, I am averaging 24.3 mpg.<br> <br>I think this is pretty good considering that most of my ride is highspeed highway, and I will admit to driving...assertively. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <br>Is this typical for others with this mileage? Should I have any concerns?<br>Thanks- Scott </TD></TR></TABLE><p>Have you gotten your oil analyzed?
Re: Oil consumption (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>1 quart every 6-7k for me. <p></TD></TR></TABLE><br>Same here, just make sure your PCV system in not plugged. I had an oil leak because of it in the past.
Re: Oil consumption (Denis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Denis</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Same here, just make sure your PCV system in not plugged. I had an oil leak because of it in the past.</TD></TR></TABLE><p>How do you figure out if you have a plugged or clogged PCV system? This is a first-heard phenomenon (for me) in the R cars...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote">Have you gotten your oil analyzed? </TD></TR></TABLE><br>Not since before I switched to Amsoil. I plan to have it checked with my next filter change.
1 - 11 of 11 Posts
