1 - 20 of 22 Posts
My car is due for a oil change. I've never had a car with a cartridge filter. Does it differ any then a your "normal " car? Do I need to use the tool to take off the filter or can I use the band type filter wrench? Or a different tool that is more available at the local auto store?
Thanks!
Matt
I've used a band type but it's hard to get in there, and I eventually caved and bought the right tool. I was always worried about cracking it, so much that I bought a spare just in case.
With the cartridge type, make sure you seat the filter in the bottom correctly before screwing it back on. There is an o ring on the canister, make sure that is replaced or not creaked.
What do you guys recommend for oil? I've always had the oil changes done at the dealership, but I just moved and the closest one if an hour away. My car has 145,xxx and has never run synthetic that I know of.
Thanks
Thanks
I recommend full synthetic. Personally I don't care what brand it is and even though your car says it wants Castrol, I doubt it really cares what brand you use either. And from now on, don't go past 5K between changes. Your PCV will thank you and you'll appreciate not spending $400 to replace it too frequently.
Thanks!
Matt
I agree with all the above, another tip I always follow is to pre fill the cup with the filter securely fitted with oil a friend said when the starting it wit a dry filter may cause damage to the turbo during the time it takes to filter through properly, could be an old housewifes tale but I always do it. And 25Nm when tightening it should prob. Be Enough also make sure the O-ring doesn't get caught .while twisting do as much by hand as possible. Good luck
Thank you all for your replies. Is the drain plug and filter pretty accessible? I am used to older cars and trucks where everything is out in the open.
Very easy to get at the plug and filter. Only problem might be ground clearance. I do mine on ramps.
As for oil, Walmart and Home Depot have Mobile 1 at $25 for a 5 quart jug. Also thru Oct there is a M1 rebate of $15.
There may be a splash shield in place under the car. It's a big piece of black plastic held in by 5 or 6 12 mm bolts. Once you remove that everything is very easily accessible.
What is everyone running for weight. I see a lot are running 5W-40 and 5W-30, but I also see some 0W. FYI I live in New England.
I run 5W-30 Mobil 1 Extended Performance.
Remember, you need almost 6 (SIX) quarts of engine oil, so you'll either have to buy an expensive single or have lots left over for the next oil change.
5W30 even out here in the hot and dry. And my PCV looked spectacular at 130K.
The links to the tool have already been posted.
I run Mobil 1 full synthetic, 10-40 and change it every 10K miles. I did the PCV at 110K miles and it was clean, but I think that's because the previous owner had an 80 mile round-trip commute and was insane (changed oil every 3K miles!).
After oil analysis, my oil is perfectly fine and good for more than 10K, but given turbo and PCV, I think 10K is enough. :D
First Oil Change
You need this tool or similar.
http://www.amazon.com/CTA-2489-86-M...8&sr=8-1&keywords=volvo+s60+oil+filter+wrench
They should have something available at the parts store but not always.
Band type will most likely not work and may damage the cartridge.
You will also need a new crush washer for the drain plug.
Stuck at home, changing oil for the first time, always had it changed at the dealer. I could not get the filter off, none of my oil filter wrench worked. I ordered a 86mm 16 flutes wrench off Ebay which took 3 weeks to deliver. The proper oil filter wrench made it easy to remove the oil filter.
Now since it had been 3 weeks since the oil was drained, I did not remembering seeing a washer on the oil drain plug. Of course, none of the oil drain plug washers I have at home fits the current plug. As best as I can tell, the dealer did not use a washer on the last oil change. Is it possible that the washer is stuck on the hole or is one not necessary? I already installed the drain plug and it felt tight but I have not filled it with any oil.
volvo # 977751. Copper or Aluminum washer will work. Even a plastic/vinyl type would suffice, but Aluminum is best IMO. They will sometimes stick to the pan and a little pick you can get it off. And yes a washer is required. Anything worth doing, is worth doing right the first time.
1 - 20 of 22 Posts
