Re: Oil Change Procedure - XC90 V8 (kartman01)
You will need a tool to remove the filter housing. Do yourself a favor and buy the special Volvo tool (it is only about $5-10, IIRC).<p>To reach the filter and the drain plug, you will need to remove the plastic skid plate. The filter can only be reached from the bottom (well, unless you have really long very thin arms <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> ).<p>From <A HREF="http://forums.swedespeed.com/zerothread?id=23422" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=23422</A>, the procedure is:<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Adam H.</b> »</i></TD></TR><TR><TD CLASS="quote">With ignition turned off, hold in the trip odometer reset button. Next, turn the ignition key to the on position (II) while continuing to hold in the trip odometer reset button. After approximately 10 seconds, a yellow <B>"!"</B> character surrounded by a yellow triangle will flash in the center console. Once this happens, let go of the reset button.<p>If you hold too long, it won't reset. I believe it will flash approximately 5 times.</TD></TR></TABLE>
