Below is a collection of Part numbers to enhance your XC90. Continue to post frequently used part numbers in this thread.
Thanks to itwontstopsnowin for posting the majority of these with his XC90 project. Here are some of the enhancements he applied to his XC90:
*Front bumper bar
*2013+ style LED tail lights
*2013+ LED Front Running Lights (Replace fog lamps)
*New style R design grille (R-Design emblem replaced with V8 emblem)
*Executive crests
*Ocean Race bumper inserts with chrome
*Silver roof rail end caps
*New style rear V O L V O emblem
*Rubber Mats
*Aluminum R-Design style Pedals
*2013+ R-Design Steering Wheel
*R-Design/Sport Blue Gauges
*OEM Sirius Radio
*OEM Premium Sound Amp and Speakers (Sounds amazing!)
*RTI 2013 Map/Firmware upgrade with 3D maps
*Wing Profile Cross Bars
2016 XC90 Wheel Center Caps: ( install thread )
31414934 - Silver
31414935 - Tech Black
R-Design 3-Spoke Sport Steering Wheel: ( install thread ) - Same Process as S80
With RTI: 30756165
Without RTI: 30756166
Chrome Tail Lamp Trim ( install thread )
Left Trim Piece: 30790284 - $39.23
Right Trim Piece: 30790285 - $39.23
2009 R-Design Dual Exhaust ( install thread)
Note: This kit is designed spefically for facelift cars (2007-2015). It seems as though it would be possible to fit it to an earlier model if you changed over the entire rear bumper. You need to purchase the exhaust kit itself, as well as a replacement exhaust gasket (if you wish). You also need to purchase one of two mounting kits. They are different depending upon whether or not you have the OEM Volvo trailer hitch. If you have an aftermarket hitch, you must get the mounting kit for NO HITCH. This is something that I discovered. The OEM hitch has mounting provisions on it for the exhaust mounting kit, however my aftermarket hitch did not. I ended up simply welding the necessary bracket to the side of my aftermarket hitch, but if I had ordered the non-hitch kit, it would have been a bolt-on installation.
Full Sport Exhaust Kit for Petrol V8 Models: 30756337 - $972.79 (Volvo Parts MSRP)
Full Sport Exhaust Kit for Petrol 3.2 Models: 30756338 - $1060.72 (Volvo Parts MSRP) May no longer be available from Volvo.
Full Sport Exhaust Kit for Diesel D5 Models: 30756339 - $972.79 (Volvo Parts MSRP)
Installation Kit for Cars Without Hitch, or With Aftermarket Hitch: 30635847 - $28.62 (Volvo Parts MSRP)
Installation Kit for Cars With OEM Hitch: 30756609 - $52.36 (Volvo Parts MSRP)
Gasket (Between new exhaust system and converters): 8672278 - $3.32 (Volvo Parts MSRP)
Nuts (To attach the new exhaust system to the converters): 985921 - $2.36 x2 (Volvo Parts MSRP)
2013+ "Silk Metal" Roof Rail Footing Caps: ( install thread )
This updates the look of the older style roof rails to look like the 2013+ XC90s.
Left Front: 31333099 - $13.91
Left Center: 31333101 - $11.25
Left Rear: 31333103 - $13.91
Right Front: 31333100 - $13.91
Right Center: 31333102 - $11.25
Right Rear: 31333104 - $13.91
If you don't already have the aluminum roof rails, and would like to fit those in order to get this look on your older model XC90, the part numbers for the silver/aluminum roof rails are:
Left: 31333095 - $281.25
Right: 31333096 - $281.25
Auxiliary Lighting Kit: ( install thread )
Note: The XC90 kit does not appear to be available from Volvo. However, I used the V70/XC70/S60 kit, and it contained all the necessary parts, and everything fit and worked perfectly. There appears to be no discernible difference between the two kits.
XC90 Kit: NO LONGER AVAILABLE
V70/XC70/S60 Kit: 30772053 - $144.56 (From Tasca)
Side Decor Kit: ( install thread )
Note: Willow Green (along with a few other colors) are no longer available. The kits I've listed in Italics are the ones that have been discontinued by Volvo. They do sell a kit which is just primed that can be painted any color you choose.
XC90-07- Primed - 30794160
XC90-07- Black - 019 - 30794013
XC90-07- Willow Green - 471 - 30794129
XC90-07- Silver Metallic - 426 - 30794026
XC90-07- Black Sapphire Metallic - 452 - 30794039
XC90-07- Ruby Red Pearl Metallic - 454 - 30794057
XC90-07- Titanium Gray Metallic - 455 - 30794066
XC90-07- Oyster Gray Pearl - 472 - 31213192
XC90-07- Shimmer Gold Pearl - 473 - 31213205
XC90-07- Ember Black Pearl - 487 - 31213218
XC90-07- Magic Blue Metallic - 467 - 30794102
XC90-07- Lava Sand Metallic - 468 - 30794111
XC90-07- Lunar Gold - 469 - 30794120
XC90-07- Electric Silver - 477 - 30794138
XC90-07- Shadow Blue - 480 - 30794151
XC90-07- Ice White - 614 - 30794075
XC90-07- Savile Gray - 492 - 31265740
XC90-07- Caper Green - 493 - 31265741
Primed Version - $2,110.34
Prepainted Versions - $2,191.17
The kit comes packaged in a giant box, and inside the box, each individual part is boxed up in a separate box with individual part numbers. This would indicate that the kit can be purchased part by part in case one of the parts is damaged, or improperly installed.
2013+ LED Tailights: ( install thread )
Recent Install Thread: XC90 LED Tail Light Upgrade
31335506 - lower, driver's side - $298 retail
30698141 - upper, driver's side - $152 retail
31335507 - lower, passenger's side - $298 retail
30698142 - upper, passenger's side - $152 retail
A small resistor is needed, here is what one user did:
2013+ LED Fog/DRL lights:2x 25W 30ohm resistor between black and white wire of the L and R Position light
2x 50W 6ohm resistor between black and yellow wire of the L and R Brake light ( example )
07 XC90 V8: Access the two wire yellow and black behind the rubber seal. I did not cut them but just peeled off the insulation in a very small area to expose the cooper wire on the yellow and black. then attached the resistor's two ends between the 2 exposed areas on the yellow and black and walla all works with NO error message (no brake or position light fault code). I also wanted to say that only adding the register on the driver side (ONE register) solved the error message problem. I did not have to do the passenger side at all.
31323701
31323702
Mirror Covers:
30756163 - Silk Metal Mirror Covers
L - 39894340, R - 39894353 - Black Mirror Covers
