· Registered
Mine has been making a similar sound recently! I’m 95% sure it’s the butterfly valve in the passenger side exhaust outlet in my case. I found a DTC code I think might be related (no lights or warnings in the dash) but haven’t confirmed.
Do you have a T6? You can see the valve if you shine a light in the passenger side exhaust.
2019 S60 T6 Inscription w/advanced & Polestar tune
· Registered
2020 S60 T6 Momentum w/ Polestar
Thank you for contributing. I reached out to the local dealer, and they mentioned that the valve is motor-driven and can fail. Sounds like you were correct! I'll keep an eye on it to see if continues.
· Registered
NP! Report back if you have it looked at. I’m planning on having mine checked when I bring it in for its 40k service in May, unless it becomes more of an issue between now and then. You can also unplug the valve while the car is turned off and it will stay open- according to others on the forum.
Do you have a code reader? I’d be curious if you’re getting the P26DC00 DTC too. I can’t find anything Volvo specific on that code, but other manufacturers (Ford, Mercedes) use it for issues with similar sound-controlling exhaust valves…
