I have a 2000 V70XC with 70k and the CEL came on, so I took it to autozone and they read out code 0455. The guy at the store told me that I probably just need a new gas cap. I read somewhere that it could be a vaccum line. <p>Will this impact the performance or hurt the car at all if I don't fix it? <br>Has anyone had this code before? If so, how'd you fix it?<p>Thanks!
Re: OBDII code 0455 help (austinJeff)
I've been manually resetting this code for a month now (I'll disconnect the battery). it usually will go 2-3 weeks after I reset it and then it will come back on. Because it doesn't come right back on I'm thinking it's not any kind of major leak. hopefully i just need a new gas cap, I'm gonna take it in next week.
Re: OBDII code 0455 help (ericd)
I'd be interested to hear what the dealer tells you. Do you know if I can use any gas cap or do I need a volvo gas cap?
to the dealer for the both of you. <p>letting autozone look up anything for a volvo? <IMG NAME="icon" SRC="http://********************/smile/emthdown.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>austinJeff</b> »</i></TD></TR><TR><TD CLASS="quote">I have a 2000 V70XC with 70k and the CEL came on, so I took it to autozone and they read out code 0455. The guy at the store told me that I probably just need a new gas cap. I read somewhere that it could be a vaccum line. <p>Will this impact the performance or hurt the car at all if I don't fix it? <br>Has anyone had this code before? If so, how'd you fix it?<p>Thanks!</TD></TR></TABLE><p>I've had the same code from my car and needed to replace the o-rings around the fuel pump and sending units. I spent days looking for the leak and then figured it out when I filled the car with gas and then went off to wash the dirty thing... As I was treating the passenger rear wheel I could see gas that had leaked from the top of the tank and ran to the bottom... Replaced the o-rings the following day and all was fine.<p>Now one thing to keep in mind, a smoke test is cheap and very fast way to diagnose a leak. You may want to do this as a first measure after replacing the gas cap.<p>Cheers,<br>Prospero
There are some decent shops that have a machine much like a fog machine...they will inject smoke into the system with a non-heated / inert fog and then you can look for any places where the fog is leaking from.<p>This takes all the guesswork out of testing soo many things.<p>Cheers,<br>Prospero
