1 - 9 of 9 Posts
Hi guys...<p>I have no idea on the ODB topic... and its something new for me.<br>What software do you lot use?<p>I'm going to be a bit on the cheap side and I have got the cable from ebay.<br>ebay has a bunch of softwaretoo but not sure which one to get.<p>on an external site ... Digimoto looks good, but too expensive and i dont think they ship to the UK.<p>Thanks
Re: OBD2 - What Software (Akash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Akash</b> »</i></TD></TR><TR><TD CLASS="quote">Hi guys...I have no idea on the ODB topic... and its something new for me. What software do you lot use? I'm going to be a bit on the cheap side and I have got the cable from ebay. ebay has a bunch of softwaretoo but not sure which one to get. on an external site ... Digimoto looks good, but too expensive and i dont think they ship to the UK. Thanks</TD></TR></TABLE><p>Go with BSR.
Re: (Akash)
what "cable" did you get?<p>are you looking for an ECU upgrade? or software to view the diagnostics through the OBD-II port?
not ecu upgrade, its purely for viewing diagnostics<br>the one I'm buying is <A HREF="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280006084036&ssPageName=ADME:B:BODO:UK:1" TARGET="_blank">http://cgi.ebay.co.uk/ws/eBayI...:UK:1</A><p>I havnt got it yet but as you're in the know-how, is it ok to get this one?
Re: (Akash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Akash</b> »</i></TD></TR><TR><TD CLASS="quote">not ecu upgrade, its purely for viewing diagnostics<br>the one I'm buying is <A HREF="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280006084036&ssPageName=ADME:B:BODO:UK:1" TARGET="_blank">http://cgi.ebay.co.uk/ws/eBayI...:UK:1</A> I haven't got it yet but as you're in the know-how, is it ok to get this one?</TD></TR></TABLE><p>Ah, I see. My bad. I don't think the BSR unit will allow you to view the OBD, but I could be wrong. I know that your cars factory ECU setup is stored on the BSR unit when you tune, so you might be able to plug the unit into your lap top and view info that way. Can anyone else confirm this?
I got the digimoto, but it's not very good with Volvo. It can see a very limited set of parameters, and the Elm sampling rate is low. There's a newer interface module and newer software version, but I have not tried them. I wish someone would hack together a piece of software that could go beyond the OBDII registers and look at the proprietary stuff like boost etc. I don't have time to do that, and I'd need to get me some proprietary info on the car to get going. So much easier with the run of the mill GMs. You can hack pretty much anything with cheap software.
so where do I go from here?<br>I take it the above cable is fine to get in the first instance?
well, as i suspected, the cable comes with software. you are very unlikely to see someone sell a cable without software, or vice verca.<p>if you don't think you want to use this software, then DONT buy the cable. you should look for software first, and it will most likely come with a cable. alex peper has a good one: <A HREF="http://www.obd-ii.com" TARGET="_blank">http://www.obd-ii.com</A><br>i think
1 - 9 of 9 Posts
