All:<p>I have a copy of <A HREF="http://www.obd2.com/" TARGET="_blank">EASE Diagnostics</A> <A HREF="http://www.obd2.com/palm/data/palm.htm" TARGET="_blank">OBD-II Scan software for Palm devices</A>. I love this software and it has worked great for me. Unfortunately it will not work on my new Palm Device (Treo 650).<p>There is a list of <A HREF="http://www.obd2.com/palm/data/palm_hotsync.htm" TARGET="_blank">supported Palm devices here</A>. Essentially your device has to have Palm OS 3.1 or higher and SERIAL HotSync cable. The serial hotsync cable is what is killing it for me.<p>THIS DEVICE WILL WORK WITH 96+ CARS, BUT DOES NOT DO THE CAN VEHICLES.<p>I paid well over $200 for this way back when and am willing to let it go for $125 plus shipping. You will get the software CD as well as the connection to the car and the converter. All you will need in addition is a Palm device and a SERIAL HotSync cable.<p>If you are interested please e-mail me, PM me, or get me on AIM. Thanks for looking.
Banned
2013 Release 3 Delphi Diagnostic Tools & Equipment DS150E Auto CDP+ Bluetooth
Delphi Languages:
English , Cesky, Dansk, Deutsch, Espanol, Francais, Greek, Hollands, Hungarian, Italiano, Norsk, Polish, Romania,Russian, Srpski, Suomen kieli, Svenska, Turkish and so on.
Delphi DS150E takes all the functionality and coverage of the DS100E and transfers it onto a PC platform. Faster diagnosis,supports diagnostics on around 54,000 vehicle systems.on more than 4000 models from over 48 Vehicle Manufacturers.Full system coverage for BMW, VAG, Ford, Peugeot, Citroen, Renault, Vauxhall, Rover, Fiat, Volvo, Mazda, Mercedes, Smart, Nissan, Subaru, Toyota, Hyundai….and more!
Delphi DS150 Diagnostic Tool Features:
1.Bluetooth Vehicle Communication Interfaces
2.Keeping update (the newest one Delphi 2013 release 3),Compatibility better than auto.
3.New design and new Hardware,faster diagnose.
4.More the 4000 models from over 48 Vehicle Manufacturer.Include 85% European models
5.Exceptional value for money – operates from a garages existing PC
6.Full-service support available, including training programs, a technical help line and more
Delphi DS150 Functions:
1.Read & Erase Fault Codes & SLR All Systems(Petrol & Diesel Engine Management, ABS, Instrument panel, Climate control, Gearbox, Immobiliser, SRS, Multifunction (Central Body, Central Locking, Convenience Systems, Chassis, Infotainment, Lights, Navigation, Seats, TPMS etc-Vehicle Specific) ),
2.Look at Live Data, graphing and saving of live data
3.Component Activation
4.ECU Coding / Parameter Adjustments / Component Configuration (initialization of new components, particulate filter regeneration, Diesel Injector coding, TPMS etc)
5.Intelligent System Scan – complete scan of all ECU / ECM’s on vehicle platform, configurable by system
6. Full Vehicle Information tree – allowing vehicle specific check of OBD functionality without being connected to a vehicle-Customer reporting system-Direct Linking to Delphi Technical Data
7. Service Light Reset and Service Interval Reset, including ‘BMW Condition Based Service’ reset and Fiat Stilo, VAG.
Audi A6, A8 / VW Passat, – Electronic Handbrake, Piston reset for before and after brake service.
Mercedes E Class (211/230) De-activation and Activation of SBC (brake-by-wire) brake system, so that brakes can be serviced.
Peugeot Additive Tank Reset and Regeneration of Particle Emission Filters
Renault Laguna II, Espace IV, Velsatis, Peugeot 607, 807 and Citroen C5 & C8 - Tyre
Pressure Monitoring Systems – Valve programming
Diesel Injector Coding for Delphi Systems
1. What should you pay attention for when you install 2013.2 Delphi ds150 software?
1) Make sure your computer do not install other version auto or cardiag m8 software. Do not have other software that is not compatible with this Delphi ds150 software.
2) Your computer system should be compatible with this software
Over 95% customers can install the software successfully. Some cutomers will meet problem when install the software. This 2013.2 software is sensitive to the computer. Once there is some influence in computer, software will show error prompt when install the software. That's why some customers say they can install the old version on computer successfully, but cannot install this 2013.2 version on the same computer.
If there is the software or your system is not compatible with this delphi ds150 software, what will happen?
It will meet the following problem:
1) Software cannot recognize the hardware, means VCI NO Found problem
2) You cannot update the hardware
3) Hardware test result is OK, but you cannot use it to test your car
For these problem, how to solve?
1) If there is other software that is not compatible with this software, reinstall the system and format the hdd. Then reinstall the delphi ds150 software again. Why you need to format the HDD? Because if there still have the file in the computer to influence for the software installation, problem cannot be solved successfully.
2) Directly install our XP system and format your HDD. Please ask the XP system link from us.
2. Recent days, one customer tell us the first activation file we send to hin is invalid, for the second time, it is OK. If you meet this problem. Please regenerate this activation file and send it to us, we will activate it for you again. DO NOT close the software before activation. Use the second activation file to activate the software again, then you can use it normally.
Package list:
1 X Delphi DS150e diagnostic unit
1 X Delphi 2013 release 3 CD
1 X USB cable
Contact Us:
Skype: obd2works
Email: [email protected]
http://www.obd2works.com/2013-relea...uipment-ds150e-auto-cdp-bluetooth-p-1878.html
OBD2 Scanner
I just got a ELM327 OBD II Scanner and loaded software Scantool on my laptop. It operates perfectly . Exactly what I desired and Now I am going to try Digimoto Lite by tomorrow. I've heard that it is much better.
Get more info here about OBD2 Scanner
Apart from that I ll also be getting my hands on an older Palm M105 and will be trying this as my scanner display instead of the laptop for portability and compact size. This is one brilliant diagnostic, dyno and data logging tool.
