1 - 9 of 9 Posts
Hey all,
I am wrapping up the final portions of my turbo back project and have 2 questions.
1) is there anything special I need for 02 bungs to weld into the DP? I bought this one (I know I need two, thats why I'm asking if this is OK or if I should get something else)
http://www.summitracing.com/parts/AAF-ALL34153/
2) Im anticipating needing a spacer for the lower(???) O2 sensor. What exactly should I pick up for that, is it as simple as a few washers (I would guess no but neer know)?
Man, am I pumped to get the last few items brought together so I can do my first REAL mod in 3.5 years of owning my baby, 3 weeks is going to go by sooooooo slow.
TIA
not sure about the bung, i would imagine someone else will chime in. In terms of the 02 spacer, 30 bucks from ipd/rallitek, works like a charm. 300 miles on it and no CEL.
Goodluck!
Hey all,
TIA
The oxygen sensors on the R are threaded standard M18x1.5
You can get the two bungs and an extender for the rear bung from this site: http://www.boostcontroller.com/index.php?category=158
angled bung http://www.boostcontroller.com/inde...tcontroller.com/index.php?page=1&category=158
straight bung http://www.boostcontroller.com/inde...tcontroller.com/index.php?page=1&category=158
angled extender http://www.boostcontroller.com/inde...tcontroller.com/index.php?page=1&category=158
straight extender http://www.boostcontroller.com/inde...tcontroller.com/index.php?page=1&category=158 (I would use the smallest opening)
I would recommend getting either an angled rear bung and a straight extender or a straight rear bung with an angled extender, so that your rear oxygen sensor doesn't contact the heatshield/exhaust tunnel wall.
A straight bung is used for the front oxygen sensor (no extender on the front!)
Cheers,
Jeff
Thanks guys, so do I need an extension if I am running a cat? I am going the E-cutout route as many have done before. IIRC, there is a way to strategically place the O2 bung so as not to need a spacer but Im not totally positive in that regard. I would guess I dont need one on the upper sensor, only the lower if that. Can spacer's be added later if I dont initially have one installed but get a CEL that requires a spacer to remedy the issue?
1 - 9 of 9 Posts
