1 - 11 of 11 Posts
Is this normal for volvo, or just the V50 MY06? <br>My car makes a heavy noise when driving. I'm pretty sure the noise comes from the tires. Had it when I still drove the 16", but with my 18" it got heavier.<p>Tires I'm driving are Dunlop Sport Maxx 225,40,18.
Re: Noisy tires V50 (Roco80)
could be abnormal tire wear. Is your car lowered? if so , I'd Highly recommend those vivaperformace adj. arms, it'll fix the uneven wear from being lowered. <p>But also check the wheel bearings, I thought my tires wear loud, but it was a front wheel bearing.... if it get's louder when you steer in one direction , most likely wheel bearing. <p>most 18s will be louder than 16s
Re: Noisy tires V50 (V50_T5)
Lowered and wheels/tires since may this year. 3 cm weitec springs.<p>A friend of mine also thought it could be the wheel bearings. I'll have that option checked later this week.<p>So you think the tires aren't the main cause?
My car was loud on 17s and louder on 18s back in May, it is lowered 3 cm. I thought it was tires but I have those adj. arms I mentioned so I assumed my tires were loud. but no uneven tire wear. <p>had the wheel bearing checked .... sure enough , had it replaced and everything was quite again. <p>does it get louder/quiter when you steer in one direction? If so.. this is a sign of one of the front wheel bearing going out. <p>Uneven tire wear will give a constant noise (getting louder with speed) but NOT louder when steering in one direction. <p>hope I could help.... let me (us) know. <p>good luck <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Probably, almost sure, definitely the wheel bearing. Took a friend for a test drive and he was pretty sure.<br>Next week, he will check which one it is.<p>I'll give an update later.<p>Thx for the help so far V50_T5.
Re: (Roco80)
My V50 had been making a lot of noise from the rear tires, and when I took it in they said they were wearing unevenly. They said it is because of the rear camber. They said they could "true"/shave the tires, but the sound would return when the tires wore down. I'm going to get adjustable arms before I replace the tires.
Re: (Roco80)
What were the symptoms of the car while driving ? <br>Mine is really loud and im not sure if its the tires or bearings?
Re: (jdsr917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jdsr917</b> »</i></TD></TR><TR><TD CLASS="quote">What were the symptoms of the car while driving ? <br>Mine is really loud and im not sure if its the tires or bearings?</TD></TR></TABLE><p>x2! Great question. Thanks. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
1 - 11 of 11 Posts
