1 - 9 of 9 Posts
Jaguar XFR
After driving around today with the temp reading at 99, I decide to park and leave the car running for about 3 mins. I get out of the car and I hear what seems to sound, as best as I can describe it, like an air leak in a tire. Checked all the tires, and they were fine. Traced it to the engine bay. I have never heard this noise before and I checked the fan and it was off. I tried to trace the sound, but my face was burning off from all the heat in the engine bay. I took a video, but I can't even use that to trace it. But you can still hear the sound. Any idea what it could be? (please excuse the phone video)
Re: noise while engine is off. (o2k)
Was it the interior climate fan that you heard? There is a function called "afterblow" which runs the climate system fan for a few minutes to dry out the evaporator to prevent moisture causing odor. It sounds like a loud whisper from outside the car. Inside you can feel air blowing out of the dash vents. That's the only thing that jumps to mind.
Re: noise while engine is off. (cdauerer)
Loud Whisper? Last time I walked up to my car and heard the fan I thought someone started my car.
Quote, originally posted by cdauerer »
Afterblow doesn't activate until at least 1/2 hour after the car is shut off.
it is most likely the ECM cooling fan.
Jaguar XFR
Re: noise while engine is off. (Needsdecaf)
Quote, originally posted by Needsdecaf »
The ECM has a cooling fan? Did not know that. Well, it was coming from that area.
Jaguar XFR
Re: noise while engine is off. (mjaffe)
Quote, originally posted by mjaffe »
Yeah, I've had that happen. Usually it's very soft. But since the weather has gotten so hot, the fan has been very loud.
2005 V70R, Midnight Blue, M66
Quote, originally posted by o2k »
It is hard to imagine that the engine cooling fan was not operating, since the car is stopped, and at an idle, it is 99 degrees ambient, and I assume at that temperature, the A/C is on.
Could be the vacuum pump located under the air box. If the ECU fan, you should hear it run for a few seconds after engine shutdown.
Afterblow, if it really is enabled, begins 50 minutes after engine shut down, and runs for 7 minutes.
Re: noise while engine is off. (rogersampson)
Quote, originally posted by rogersampson »
Doh, I mis read the initial post. I thought he had shut the car off.
Not the ECU fan, then. You only hear that when the car is off.
Jaguar XFR
The car was off. Not idle. I had it idling for 3 mins to cool down the turbos. Then I shut off the car. When I got out, that was when I heard the noise.
1 - 9 of 9 Posts
