Hey guys. Had some trouble with my stock stereo so I decided to install an aftermarket one, which ended up running fine. Since the stock volvo headunit has 2 connections of wires however, I failed to install the two dash speakers into the new stereo. I fear that I might have accidentally blew a fuse during this process, and so I checked in the box under the hood, and indeed the radio fuse needed replacing, and so I proceeded. After I replaced it however, I still had no power going into my stereo. From owning other cars, I'm sure there is another fuse attached to the constant v12 or another wire behind the dash somewhere, however I'm not sure where it may be. Does anyone know where it may be located? And if that extra fuse isn't there, does anyone have a clue as to what might have happened? Thanks.
1996 Volvo 850 N/A 5-speed
