1 - 11 of 11 Posts
Weird got in my car litteraly after 5 min and noticed the car has no boost. I have a PPC kit and exhaust as my only mods plus I have had my maintenance light on for 3 days. What can It be? The boost selenoid maybe? It's noticably sluggish and very obviouse that there is no power.
Re: No BOOST? (zigger)
Common problem for '06's. It's a computer problem. I've had the problem, and several other 06 R owners. I bet your temp gauge is ready cold as well. Volvo knows about so it shouldn't take long to fix.
Re: (zigger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zigger</b> »</i></TD></TR><TR><TD CLASS="quote">really? So what needs to be done exactly?</TD></TR></TABLE><p>Assuming this is your problem - and it I'm pretty sure it is - just bring your R in to your local dealer. They should be pretty aware of it. It is basically just a download from Volvo into your car that will solve the problem. The somewhat frustrating part is that this is occuring on a lot of '06 R's (mine and Chris' come to mind), but Volvo doesn't seem to want to simply download the software upgrade on cars as they come in for service, instead they wait until the problem arises. If your temp gauge is reading cold, I can guarantee you this is the problem. Once again, it is unique to '06's R's and it shouldn't take long to fix (uhh, download). The engine is going into a limp home mode by limiting boost to protect the engine from a problem that is actually not occuring. Computer glitch.<br>I believe the problem even popped up when R Salesman was taking someone on a test drive! <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: (zigger)
maybe your car got raped when you weren't paying attention? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
Check the vacuum hoses in and out of the boost controller. If disconnected, no boost. <br>I can confirm, they do come loose. One does not come with a hose clamp from the factory. It is low pressure, so i guess that Volvo thought it did not need to be secured.
Re: (jdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jdog</b> »</i></TD></TR><TR><TD CLASS="quote">maybe your car got raped when you weren't paying attention? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> </TD></TR></TABLE><p>I think I read somwhere on the bimmer forum about an M3 that got raped and to retaliate he sabotoged your car.... if you see an M3 reving his engine at you in the next couple days watch out! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> <p>(seriously though, prolly the solenoid/computer. Should be an easy fix)
Re: (zigger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zigger</b> »</i></TD></TR><TR><TD CLASS="quote">really? So what needs to be done exactly?</TD></TR></TABLE><p>Seems to be one of two things. Both related to the car's inaccurate reading of the water temperature, and therefore dialing back the boost into limp mode.<p>1) More common, download of the ECU which fixes the temp. monitoring problem.<p>2) Less common, only 1 or 2 instances I can remember hearing it (and maybe those were incompetent dealers) need the coolant temp. sensor replaced. <p>Start there. Actually start by unloading the PPC, which you will need to do going to the dealer anyway.
Re: (needsdecaf)
Happend to mine in June. I reset the ECU and it's been fine since. That was a mistake since I probably can't get the dealer to fix it until it happens again <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br> Zigger, you should go see your buddy at Villa.<p>LTA<br>
Re: (needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Seems to be one of two things. Both related to the car's inaccurate reading of the water temperature, and therefore dialing back the boost into limp mode.<p>1) More common, download of the ECU which fixes the temp. monitoring problem.<p>2) Less common, only 1 or 2 instances I can remember hearing it (and maybe those were incompetent dealers) need the coolant temp. sensor replaced. <p>Start there. Actually start by unloading the PPC, which you will need to do going to the dealer anyway. </TD></TR></TABLE><p>#2 was the culprit on my wife's car but that has been the only hiccup with her '06 since new.<p>Regards,<p>Derek<br>
Re: (bb vign)
The most <A HREF="http://www.alldata.com/tsb/Volvo/1145602800000_1146466800000_TNN28-67/671.html" TARGET="_blank">recent TNN</A> lists the affected cars by chassis range (which is MY06 only 500000-552807). Your chassis number is the last 6 digits of your VIN. The TNN goes on to list the ECM s/w part numeber that require the upgrade. If your ECM s/w part number is not listed you already have the upgrade and it's something elese. If you have NAV you can determine your ECM s/w part number.<p>Mine falls into the affected chassis range but my ECM part# indicates I have the update. So in may case it's probably the ECT sensor or something eslse. Since resetting my ECU when it first happened it has not come back again.<p>...anyway, the Ziggmiester pulled fuese 6 and 19 last night to reset the ECU and then took off like a bat out'a hell with more BSR boost than you can shake a stick at <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <p>LTA<p><br>
1 - 11 of 11 Posts
