1 - 1 of 1 Posts
no boost in 4th gear revisited ...
<A HREF="http://forums.swedespeed.com/zerothread?id=66802" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=66802</A> As per this thread. This problem has appear on this site before. Wanted to know if a new fuel pump did indeed fix the issues?<p> I recently just got my ETM replaced and had new ecm software updated that related to it as well as a new maf. Is it possible i am still in adaptation phase? Basically if i try to build any boost in 4th it cuts off at around 10psi. Boost fades like there is no power i have to shift out of the gear to get it back. Flooring the gas pedal does nothing. <p>One more thing i see TCV is mention but i have ipd's i would think the higher quality part wouldnt fail like this. it wasnt clear that was even the part that was causing his issues.<p>Thanks<p><br><i>Modified by uvil at 4:09 PM 7-6-2009</i><BR><BR>
<i>Modified by uvil at 4:10 PM 7-6-2009</i>
1 - 1 of 1 Posts
