Re: Newbie Alert! Looking at a 94 850 Wagon, 135k... (JZ)
I still have my 1996 Volvo brochure (just found it!), so here it goes for GLT stats.<p> <B>ENGINE</B> <br>Transversly mounted, 2.4L, 5 cylinder double overhead cam, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-in iron cylinder liners, micro-processor controlled multi-point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor. On-board diagnostic system.<p>Horsepower (SAE net): 168 @ 6200 rpm; @ 6100 w/auto<p>Torque (ft.lbs., SAE net): 162 @ 3300 rpm; @ 4700 w/auto<p>Compression ratio: 10.5:1<p> <B>TRANSMISSION</B> <p>5-speed manual transmission with synchromesh on all speeds and reverse; Final drive ratio: 4.0 (not available with Turbo except Canada)<p>4-speed micro-processor controlled automatic with lock-up torque converter and selectable shift modes (Economy/Sport/Winter)<p>Final drive ratio: 2.74 (2.54 with Turbo)<p> <B>SUSPENSION</B> <p>Front: MacPherson strut with asymmetrically mounted coil springs, hydraulic shock absorbers, 20mm stabilizer bar.<p>Rear: Delta-Link semi-independent rear suspension with coil springs, gas-filled shock absorbers, 19.5mm stabilizer bar on sedan.<p>Sport Suspension Package:<br>21mm front stabilizer bar<br>20mm rear stabilizer bar<br>Extra firm shock absorbers<p> <B>STEERING</B><p>Power-assisted rack and pinion<br>33.5 ft. turning circle (34.5 ft. Turbo)<p> <B>BRAKES</B> <p>Four wheel, power assisted disc brakes<p>Front: 11-inch diameter, ventilated discs with sliding calipers<p>Back: 11 1/2-inch diameter solid discs; Three-channel anti-lock braking system (ABS); Separate self-adjusting mechanical rear-wheel drum parking brakes<p> <B>DIMENSIONS AND WEIGHT</B> <br>Wheelbase 104.9 in./266.5 cm<br>Overall length 183.5 in./466.0 cm<br>Overall height 55.7 in./141.5 cm<br>Overall width 69.3 in./176.0 cm<br>Front track 59.8 in./152.0 cm<br>Rear track 57.9 in./147.0 cm<br>Interior volume (EPA) 111.5 cu ft./12.4m3<br>Trunk capacity 14.7 cu ft./1.6 m3<br>Curb weight 3148-3208 lbs. / 1431-1458kg<p><br> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br>
