1 - 20 of 24 Posts
Installed a new set of Volvo Portia wheels/tires on my r today in addition to a car wash and hand wax.Question for you all, my tpms light came on due to these being new sensors. Does anyone know how to reprogram the new ones? I tired driving over 25mph for over 10 min but that didn't work. I wheels are from a 2016 which I read from somewhere Volvo does not use tpms any longer but abs sensors to measure low tp. The valve stems are rubber. Could this be true?
The TPMS system for your car (and mine) requires the use of the TPMS sensors in each wheel, and you can see that by the use of metal valve stems. If you have rubber ones, then you don't have the TPMS sensors installed. The new cars do not have TPMS sensors in the wheels, but measure changes from the braking system, as you note.
Okay thanks for the confirmation. Now instead of me having to buy another set of sensors and having to get these tires rebalanced, is there a way for the dealer to deactivate my tpms system?
My ixions are 18s, and I think I will be hanging on to them. The tires on them have decent tread left so I plan on running them in the winter months up here in ct.
Gotcha. I would love Ixion 19s but at close to $600 per wheel new, ouch! Back to topic, are these Portia wheels standard fare on MY 16 S60's?
These wheels are optional on the t5 and drive e models for 2016. The 2016 r designs still have ixions. I wanted 19 inch ixions as well but they are expensive. I picked these up for a very very good price and think they look quite clean and classy.
The car looks hot!
Administrator
Confirm that the sensors you get for the new wheels match your 2012 TPMS frequency requirement. I think 433MHz is the frequency for 2012 through 2015.
The wheels look very sharp with the Passion Red!
Hi S60rd, beautiful car. I noticed the wheel arch gaps are nice and tight. What springs/shocks have you got on?
Sent from my HTC_0P6B using Tapatalk
I'm on the market to look for lowering springs and I was thinking of the Eibach Pro Kit.
These are actually just stock springs/shocks. The 19 inch wheels are technically 1 in taller in diameter since the sidewall spec of the tire doesn't change between 18/19 inch rims, so it fills the wheel gap a little more.
Im not 100% sure, but I don't think that is correct. iTPMS isn't yet in use IIRC.
The new TPMS sensors are rubber stemmed, not metal, so it's easier to be fooled. We were under the impression the new XC90 was using iTPMS, but found rubber stemmed TPMS sensors on the wheels.
Looks great! I Knew that they would look good up against Passion Red. Hopefully one day I'll be able to get a set down the road for my V60RD.
Great look! Love the elegant simplicity.
I don't know if anyone answered but I've heard it is illegal to deactivate tpms. One thing I read recommended throwing a set of sensors inside a spare tire and air it up to spec. lol
Sent from my SM-N910T using Tapatalk
Discussion Starter · #18 ·
Few more shots
Fantastic. I can say, with certainty, that this is the only wheel I have seen looking better than the original (and great looking) IXION II wheels!
Love the additional shots!
1 - 20 of 24 Posts
