1 - 14 of 14 Posts
Mathue,
Did these ship with the vent locks attached?
Thanks,
Steve
Nope, you have to assemble the latches which isn't too hard, but it does involve a coil spring which at one point went flying on me. Thankfully I did find it afterwards.
I had to re glue the latch on one of mine which required removal of the vent window from the car. I found the R&R was fairly easy, less than 5 minutes each to remove and reinstall the glass. Did you also replace the weather stripping - that is a bigger job.
The vent windows that VP sold me, while OEM Volvo, the lower mount with the nice big screw was epoxied and not removable. I had expected them to be removable which certainly would have been WAY easier.
The rubber seal for the vent window is surprisingly in decent shape, though I need to give it a real good cleaning and nourishing. The door seals though . . . yikes they are bad.
Are you sure it's not Silicone?
I just repaired mine as per 142guy did, and the bottom screw had silicone on it, I don't remember ever removing it before.
Could just be very tight ....
Perhaps an over zealous application of thread locking compound? Maybe they used blue instead of red (or whatever the Volvo equivalent of locktite is).
Try using a heat gun to heat up the screw, if it IS epoxy heat will also cause it to melt and release the bond, a large soldering iron applied directly to the screw may do the trick.
Were you able to remove the screw?
If so, what method did you use?
Steve
Nope, I took things more apart using a hammer and axe and gorilla glued it back together. ;) ;) ;)
Actually no, but I did take things apart more than I had expected I would have.
It is SO nice to have them, it's such an improvement.
For the life of me I cannot get my vent latches to stay attached to the glass. I was most careful in cleaning it and gluing it with rear view mirror glue. Even sitting in climate control for a year and not moving it still popped off.
Did you use the Loctite kit with the separate adhesive and activator / pre treat? That is what I used and the latches are still stuck on, although I don't think I have opened the passenger side in the last 3 years so it doesn't get tested a lot. Is there a chance that there is something on the attachment pad on the latch that is interfering with the adhesive?
I will look at what I used but I thought it was yellow loctite for glass applications.
1 - 14 of 14 Posts
