May 12th 2019
This weekend, I spent my time on adding the 12v socket and 2 led lamps (+ wiring) in my V60
I have based all my work on
A/ Lamp in the trunk tutorial from Stef1 :bow:
B/ 2nd lamp in the trunk tutorial from VolvoV40
C/ 12v in the trunk PDF Manual From Volvo
Part:
Volvo 12v Socket 31435602
Digi-Key 670-2217-ND green Conn Socket
Digi-Key 670-1785-1-ND pin
Digi-Key CN538B-25-ND black wire
Digi-Key CN541R-25-ND Red wire
Lamp OEM 1286317 1286317 (** I put OEM lamp because I order 2 different brands on Ebay and IPD and it does not plug correctly **)
I will not spent time on how I unstrip all the plastic since Volvo did it well in the pdf (link above) and Stef1 in his tutorial
1st lamp
<img src="https://imgur.com/m9G0aYI.jpg" width=30%>the plug is hidden in the grey foam bag here (right wing)</img>
<img src="https://imgur.com/Gc3TT9x.jpg" width=30%>connected the lamp to check..it works</img>
<img src="https://imgur.com/Pg764kL.jpg" width=30%> mark the spot to cut</img>
<img src="https://imgur.com/KINIkkc.jpg" width=30%>put the lamp</img>
<img src="https://imgur.com/D3xXNqN.jpg" width=30%> done</img>
Overall, this part took me 20min to unstrip the plastic, 5min to cut properly, and 1min to plug and put back for the pic
!!!Disclaimer, I just put quickly for the lamp since I am adding a second lamp so I will use the wiring again!!!
***Wiring part for the 2nd lamp****
To make it short, I did not take any picture. I will do it if anyone needs it. What I did is:
-remove the plastic from each wire (3) to the trunk lamp
-double the wiring on the right side with the red and black wires I ordered from Digi-Key
-use 3 pins and a green socket conn on the other side (left wing)
-protected all the wiring from Right wing to the left wing (using the same path than the original wiring/looming in the car
2nd lamp and 12v socket
<img src="https://imgur.com/xxCnjaq.jpg" width=30%>remove the plastic protection from left side in the trunk</img>
<img src="https://imgur.com/ePnrDkJ.jpg" width=30%>12v socket space already delimited by Vovlo</img>
<img src="https://imgur.com/eAkP5hc.jpg" width=30%>where is the plug???</img>
<img src="https://imgur.com/ZLyCfr2.jpg" width=30%>got it! it was hidden behind the green plug</img>
<img src="https://imgur.com/cASjVef.jpg" width=30%>the 15amp fuse was already in </img>
<img src="https://imgur.com/xRtY4sC.jpg" width=30%>3minute later...</img>
<img src="https://imgur.com/hObIe4x.jpg" width=30%>12v socket in place</img>
<img src="https://imgur.com/fMPxq3B.jpg" width=30%>2nd lamp installed after cutting the space for it</img>
<img src="https://imgur.com/ZAepJxM.jpg" width=30%>all wired and ready for being put back</img>
<img src="https://imgur.com/aoeBw29.jpg" width=30%>once all placed back and reassemble</img>
These mods are just a must have. When it is dark, I can see all my trunk and find easily what I want. The 12v socket is awesome since I went for a road trip and kept the food and drinks cool
Part:
1st lamp
