thanks for input crazyace1104The coaxial: my best guess is for satellite radio !
Flex pipe is probably coming apart.
Time for aftermarket Downpipe!
I would only recommend obx if your willing to put time and effort getting it to fit properly. Some people had issues with it not being made correctly( myself included). But there is a catted one on eBay for 300$. Otherwise if you have the coin ipd is good and so is phuzzymotorsports Downpipe. Though some question the weld job....thanks for input crazyace1104
which down pipe do you recommend?
i was looking into the obx due to the cost but they come catless. how do you get around passing inspection?
Oo ok..L
I pass inspection be cause I use a 90 degree o2 spacer that moves the o2 away from the hot unburnt gasses.
http://item.mobileweb.ebay.com/viewitem?itemId=300665169945&index=2&nav=SEARCH&nid=64990741465
obx=3in pipeOo ok..
Is there any differences between the obx and the stock down pipe besides not have a cat?
Oo ok, i didnt realize the obx was larger than stock.. Ill definitely have to look into that..obx=3in pipe
stock=2.5in
There is more flow, faster boost coming on, MORE NOISE!![]()
HarrisonWhere in NY are you?
Welcome!so my mechanic called me up and told me it was the fuel pump..
luckily the car still has 30day warranty so the used car dealership "should" cover that
