1 - 8 of 8 Posts
Hi guys. Recently picked up an '01 S60 2.4 with 148k miles on the clock. This is my first Volvo, and hopefully you guys can help me with a few things.
The first question I have is this button on the center panel. What exactly does it do? I looked in the appropriate section of the owners manual but it's not pictured.
My next question has to do with power door locks. Yesterday, the battery died and I had to jump it. After I did that, the power lock system wouldn't work. Whenever I pressed the button on the door, nothing happened. This was working before the battery died. What exactly is causing this?
Thanks in advance for any help. You guys seem like a knowledgable S60 group.
Thanks for the help. That really confused me the other day.
To fix your door lock issue try resetting it by using the key in the drivers door to lock then unlock the car three times in a row. If that doesn't work check fuses.
Thank you! I just did that and it worked.
it locks the trunk so when you give a valet the valet key they can not access the trunk
i dont get that cant they just shut it off if you were to be a stealing valet
It can only be activated or deactivated with a master key. The "valet" key will only work to run the engine. It does not have access to the glovebox or the trunk.
1 - 8 of 8 Posts
