1 - 15 of 15 Posts
So i need new struts on my AWD 2004 s60R, but i cant tell if i need the C2501 or c2502. Is there a real difference between the 2 models? rockauto has them for $640 shipped for both models, but i found the C2502's on amazon for $590 shipped. Can either one go on my R?
Thanks!
There shouldn't be any difference and you can't buy an R strut for $60 ANYWHERE, so that's not correct
Try www.tascaparts.com
What? $60? What are you on about?
probably forgot his reading glasses, I know my grandfather does the same thing :D
I don't think there is really any major difference between C2502 and C2501 as people have used both for the front with no problems from what I have read multiple times on this forum regarding these shocks. I think the difference in # is between the VR and the SR but shouldn't cause any problems.
The fronts shouldn't matter what number you use, IIRC thought only the rears are different from SR to VR.
Use C2501 and C1501 (as per search on Monroe site)
R and VR use the same struts.
AFAIK, the difference is an ABS line clip that some have said can be replaced with a ziptie on the 2502s. I have the 2501s sitting and waiting to be installed this weekend.
Discussion Starter · #14 ·
Ended up ordering the C2501's from rock auto. Thanks for the help and laughs! I know im still a newbie with this car, but any advice which spring seats and mounts should i get?
The search button (or google searching this forum) is your friend. This has been covered a million times. As far as spring seats, you want XC90 or iPd HD ones. They're basically identical.
1 - 15 of 15 Posts
