It's time I replace the rotors and pads on my 850. I didn't get a big brake kit, but I am stepping up to cross drilled rotors. I am also planning on painting the calipers to make the new setup look more fresh. I haven't done this before but have printed out a few good instructions with pictures and helpful hints. <p>My question is this. How do I know how many shims to use in the install? Do I compare it to what is originally there, or is there a better easier way to judge this? Any other helpful suggestions would be greatly appreciated.
Re: New brakes on my T5R, shims question? (jarediii)
i assume u mean the shims to reduce noise? u only need one behind each pad, with a decent application of anti-brake squeal lube. just don't get the lube anywhere on the pad friction surface or the rotor, otherwise, u won't be able to stop
Re: New brakes on my T5R, shims question? (steve s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>steve s</b> »</i></TD></TR><TR><TD CLASS="quote">i assume u mean the shims to reduce noise? u only need one behind each pad, with a decent application of anti-brake squeal lube. just don't get the lube anywhere on the pad friction surface or the rotor, otherwise, u won't be able to stop</TD></TR></TABLE><p>But it'll sure be fun trying.<p>Just remeber not to paint the entire disc like that 1 VW kid did a few years ago <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
Re: New brakes on my T5R, shims question? (doug242ti)
Thanks for the hints. <p>I am going to have the calipers off w/o pads on it anyways, because I am replacing the rotors. So we won't have to worry about painting the rotors or pads. <p>Anyone else finding it hard to have someone turn your rear cross drilled rotors? I found someone to do the fronts, but everyone else is claiming they are scared or don't have the proper brackets to properly turn the drilled rears.
