1 - 6 of 6 Posts
My VR just turned 148kmiles, and it's time for new brakes. I picked up the parts from DRT in MA months ago (can't believe that was March http://forums.swedespeed.com/showthread.php?171618-Picked-up-new-rotors-from-DRT )and just now found the time to leave my car with my indy.
Good to go with rotors, pads, Ti Shims, and rubber nipples
Old front left
New front right
Old rear left
New rear right
Replace Clutch Pedal switch
Replace Front O2 Sensor
Replace Clock Spring/Steering Angle Sensor
Crazy that those were the original rotors on the car, and my indy tells me that my rears could have run much longer. And just my second set of pads. Something to say about sales and highway driving.
The car feels great, as the new O2 sensor seems to have smoothed out the engine. A noticeable difference.
Kudos to TKi and the great service they deliver. Always top notch. :thumbup:
Scott
I'm surprised you didn't do the brakes and rotors yourself honestly; it's so easy to do. :)
New rotors look nice!
Is the replacement clutch position sensor a preventative measure or did you have symptoms?
I had two warnings pop up a few times this summer: Anti-skid Service Required and Chassis Settings Temporarily Off.
I'm told that failure of the steering angle sensor can make that happen.
I also had a problem with my cruise control dropping out. The clutch sensor failing created that issue.
Time is the issue. As the car was in for other problems, I let the pros handle it. :thumbup:
You have exactly what I was planning on buying/installing: HPS on PowerSlots, not drilled. How do you like the HPS? Any pulsing from the slots?
I just bedded them and haven't really driven. Give me a few days on that.
1 - 6 of 6 Posts
