German Volvo tuner HEICO SPORTIV has recently introduced a range of accessories for Volvo’s new S40. Details as provided by HEICO SPORTIV are below.
Engine
A Volvo has always been something more than just a simple means of transport. And why shouldn't this move a little bit more speedily? You will appreciate the optimized torque characteristic and the harmonic development of performance created by the HEICO SPORTIV ECU upgrade. This upgrade implies the re-programming of the original control unit incl. an official technical authority approval (TÜV) and a 24-month warranty.
Your Volvo passenger car, the sports air filter is an ideal completion to the exhaust system. It guarantees for a 40% higher air-flow rate than the standard filter. This results into a higher responsiveness and engine performance. Moreover, it can be easily cleaned using the HEICO SPORTIV cleaning kit and has thus a nearly unlimited life.
Exhaust System
An extraordinary sound event! The HEICO SPORTIV twin-branch exhaust system will catch your eye by its unique and outstanding sportive look on the right and left side made out of high-quality stainless steel beginning at catalyst. In combination with the HEICO SPORTIV sport air filter, the total air flow is thus optimized and provides for an optimum in engine response. Moreover, the custom-tailored system will enhance Your Volvo by a nice sonorous sound.
Sport Brake System
The HEICO SPORTIV Steel Flex Brake Line Kit improves the feeling for the optimal action point. It reduces fading tendency of the braking system and provides for a long-term protection against stone impact and damages.
Suspension
HEICO SPORTIV’s Spacer Set offers more driving stability, more optical effects: The track enlargement is realized by two high-strength, corrosion-protected spacers per axle, which can be used for both front and/or rear axles.
The lowering sports springs (30 mm) distinguish themselves by a progressive springing characteristic with increasing compression and an out-balanced driving comfort during standard driving. They can be recommended rather to enhance the optical aspects than for the modification of the driving behavior. They cannot be combined with right-height adjustment.
Wheels
Volution, the sports rims of HEICO SPORTIV: Exclusive and thus rare, discreet and perfectly finished. You will appreciate the rim we designed with its dimensions of 8x18, because of the elegant five-spoke design that will not date, which enhances Your Volvo with a sportive and individual look.
The select HEICO SPORTIV sport wheels of your Volvo will not only underline ist individuality but also adjust to a higher lateral acceleration and guarantee for an increased driving stability because they have been manufactured according to the high quality standards of HEICO SPORTIV
Design
Modify Your Volvo's front. The exclusive HEICO SPORTIV front grill consists of a chrome frame made out of PUR-RIM with an integrated grid mask including the HEICO SPORTIV front badge.
The front spoiler emphasizes the sportive-dynamic shape of the Volvo V70. The front spoiler with its sophisticated design is made from high-quality GfK plastic and fascinates not only by design but also by a custom-tailored and easy fitting.
HEICO SPORTIV also offers a rear lip and rear spoiler to further enhance the look of the S40.
Interior
Improved grip: Aluminum foot pedals with mat finish and rubber inserts, available for gearshift control (three pedals) and automatic transmission (two pedals).
HEICO SPORTIV is distributed in the United States by IPD USA.
More info:
www.HeicoSportiv.de
www.ipdusa.com
For more discussion on this story, click on the link to our discussion forums to the left.
For more photos of this story, click on the link to our gallery at the right.
