Re: Nerve-wracking one-way roads and blind corners - fjord driving (Spotter)
Driving in Norway is easy as pie. Road surfaces are usually better than what you find in the US.
A lot of the curvy mountains roads have been replaced by impressively long tunnels, but I'd recommend staying on the secondary roads so you get to see what you came for.
Speed limit in Norway in rural areas is usually 70 or 80 clicks. So, yes, it takes time to get from one area to the next, especially if you take the old roads which go around mountains and fjords. What a bird can fly in 15 minutes might take you 1 hour to drive. Not a lot straight roads in fjord country.
Make sure you know the road signs. As usual the US had to do things differently than the rest of the World. And also get VERY familiar with who has the right away. Unless on a bigger road (and there is a correspoding sign that tells you this) a car coming from the right has the rightaway whenever there is NOT a stop sign. Driving through towns when you come to intersections you'd better know this or you might end up with the grill of an Opel in your right door.
So if your road has one of these, drive on
If your road has one of these
be careful of traffic to your right.
