So I had my SS brakes lines installed (JimLill era ones, pre-Takspeed but should be EXACTLY the same sans different color). Anyways, we keep on getting a leak in the brake system. I found out the hard way after the brake pedal dropped to the floor after a block. So we rebled the system a second time and it's still doing it. Is there a trick to install these? Did Takspeed's lines change over Jim's? We are going to take a look at it again tomorrow. If not, the stockers go back on.<p>vizwiz - any comments? TIA!
