1 - 14 of 14 Posts
Re: Need quick answer (JABRD__s60R)
I'm running mine with out also. Seem OK
FWIW, the rule of thumb for any threaded fastener is that 3 full threads of engagement will yeild the spec'ced performance from said fastener. Any more than that is just cake.
Re: Need quick answer (Quick Brick)
Had mine on for nearly a year, no problems
Re: Need quick answer (JRL)
I installed my 5mm spacers with the standard bolts and these get about 5 full turns on the treads. I have re-checked torque and it has been OK. I do not think you need new bolts for 5mm spacers.
Re: Need quick answer (Jayam)
Well everything went well until I got the last lug and couldn't get it to thread at all with the spacer in place
took it off and everything was fine
Leaving them off for now. Anyone had the dealer fix the rub issue?
Don't tighten the other lugs all the way before you get to the last one.
Re: Need quick answer (jdog)
Nope, didn't do that. Also tried getting this one going first and couldnt get it to thread
Quote, originally posted by JABRD__s60R »
You have some sort of odd problem, they should fit just fine
The threads on this bolt are perfect but I'd think they would still work. Might try to get another lug and give it another go.
Re: Need quick answer (stevectsai)
A set of new bolts is not that expensive. The spacer manufacturers are not going to recommend sticking with the stock bolts, although you might get away with it. Only trouble is no locking bolts in the longer size.
1 - 14 of 14 Posts
