Just got a nice original red 164e, which runs beautifully, but has a massive power steering leak somewhere around the reservoir. How can I detect this? Are the hoses replaceable? Also, I really need a turn signal switch, as the one it has broke off... Thanks
On mine the return (no pressure) hose rubbed through against the inner fender. I cut it at that point and put a piece of ½" conduit inside with a couple of hose clamps.
Can you post a pic of the turn signal switch?
I made some new p/s hoses with stints and 3/8" hose... Hope it works! Should there be a rubber gasket between the wing nut and the lid on the p/s reservoir?
