Transmission 1
Transmission 2 (which I believe to be an M40)
Intake Manifold 1
Intake Manifold 2
Misc. plastic
Underneath the output flange on both transmissions you'll find a little brass plate that has the transmission type. Basically flip the transmission up gently onto the bellhousing a bit and look at the bottom of the trans under the output.
That being said, the top one is a P1800-type "extended housing" M40. The other one is a 122-style "long shifter" M40.
The big plastic disks/drums go under the door handles and maybe the window handles to keep from damaging the door upholstery.
Be sure there is a spring under the upholstery.
