Hi
A problem has arisen with my 2006 S60R (manual +50k miles).
The problem is intermittent and has the following symptoms.
When moving off from junctions or applying full throttle from low speed in 1st and 2nd gears, all power goes to the front left wheel causing torque steer and loss of traction (even with DTSC on) - then power is shoved back to rear wheels as it should.
If I stop and turn off ignition this sometimes "fixes" the issue.
I have no error codes or messages.
The only other items of note are I hit two large pot holes recently - one with right front and the other with the left front - but that was 10 days ago. I also have the RICA PPC upgrade.
My car is out of warranty 2 weeks !!!!!
Thanks in advance
Sean
Thanks in advance
Sean
