1 - 8 of 8 Posts
2006 v70r 138k, Sold : 2004 s60r, 1999 s70T5
I cant figure out where this wiring harness is supposed to fit. Could someone take a picture let me see....THANK YOU!!
The area is the passenger side firewall, in the engine compartment. The wiring harness is circled.....where the hell does it go??
Can't see the pic, but I assume its the plastic piece that is meant to clip onto the strut tower brace. There is a little hole that it clips into.
Yes, thats the one...it has like a hammer head at the top of the piece.....so the cut out at the bottom of the piece attaches/loops to one of the hard metal lines?
On my 2004 the bottom does not attaches to anything. It's only the top that attaches to over the engine support bracket (the bracket between the support and the strut tower). If yours is not attached it may be that the fork at the top of the plastic harness support is broken. If the top is like a hammer instead like a F it means it is broken. I have the part number at home if you need it. It was hard to find the P/N but easy to order after that.
Yes, it is shaped like an F.... i will tie wrap it...any chance you have a pic?
Someone else had made a thread about this a couple days ago
Saw this thing (green) dangling around behind the engine today whilst cleaning the "biological rubbish" out of the plastic that the windshield wipers are mounted through.
after some investigation of my own I have concluded that it connects to the mount for the upper engine mount bar (Item "A"):
Can anyone confirm/deny this?
Thanks!
It clips the the inner fender just below with engine mount cross bar. It's your front, right 4C connector.
Sent from my SM-N910V using Tapatalk
1 - 8 of 8 Posts
