1 - 10 of 10 Posts
Discussion Starter #1
Bought the 05VR used and I don't believe the tranny fluid has been flushed. I took it to a few indies but they said it can't be done.???:confused: is this accurate? If not. Can someone local show me how this is done? I'll supply beer and pizza. Thx
iPd sells a kit that works really well for the 5speed.
Check it --> LINKY
Also here's their instructions --> LINKY
Where are you located?
NorCal, never mind.
THe process is pretty straight forward, you could follow the IPD directions or written directions posted somewhere here.
Search Gibbons method.
Discussion Starter #5
Thanks for the link gents. Since im doing 12-14 qts of this stuff. What fluid is more economical to use? iPD recommends Mobile ATF 3309 but there is also a Toyota fluid type III or Type IV. Thanks again
Use Toyota Type IV it's the same exact thing as 3309.
Discussion Starter #7
To clarify for the 05V70 with auto tranny.
Where do I plug the clear flush hose? Is it to the end of of the lower or upper radiator return line?
Discussion Starter #8
Success!!
You use the lower radiator line.
1 - 10 of 10 Posts
