1 - 12 of 12 Posts
<br>The singing comes and goes, but I first noticed it a few days ago. When I would coast in a certain speed range (10-15 MPH), I would hear a harmonic sound probably around 440Hz and loud. The pitch was not tied to speed (either engine or road) and stayed constant throughout. Today I also noticed it again as I was stop 'n going around town at low speeds. <p>Given that is not tied to speed, I'm thinking possibly steering related. Almost sounds like when I went low on steering fluid last summer, except that all the sounds now are happening in a straight line. <p>Any ideas?
Re: Name That Tune: My R Started Singing To Me (vizwiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>vizwiz</b> »</i></TD></TR><TR><TD CLASS="quote">The singing comes and goes, but I first noticed it a few days ago. When I would coast in a certain speed range (10-15 MPH), I would hear a harmonic sound probably around 440Hz and loud. The pitch was not tied to speed (either engine or road) and stayed constant throughout. Today I also noticed it again as I was stop 'n going around town at low speeds. <p>Given that is not tied to speed, I'm thinking possibly steering related. Almost sounds like when I went low on steering fluid last summer, except that all the sounds now are happening in a straight line. <p>Any ideas?</TD></TR></TABLE><p>Forgive the tone deaf, but where on the scale is 440Hz? Does it only hapen when coasting or also when on the power?
Re: Name That Tune: My R Started Singing To Me (needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Forgive the tone deaf, but where on the scale is 440Hz? Does it only hapen when coasting or also when on the power? </TD></TR></TABLE><p>Coasting, except for a couple of quick shots when releasing the clutch from a standstill.
2005 V70R, Midnight Blue, M66
To a musician, (I am not one) 440 Hertz is A above middle C.<p>In regard to the problem could it just be something picked up in the tire, but that would change with speed.
Get your brakes checked. I had the same problem and they replaced the rotors and pads. Noise is gone. There is a TNN.
Re: Name That Tune: My R Started Singing To Me (LA-s60r)
Do you have a TNN#? Are you talking about this brake squealing fix? It's the only potentially relevant TNN I can find on volvotechinfo, but that is just adding shims, not replacing pads and rotors. I had this TNN (below) applied last year.<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote »</i></TD></TR><TR><TD CLASS="quote"><br>Front and Rear brake squeal<br>Item: TNN51-09-2005-03-30 Page Count: 3<br>A front brake caliper dampener and new rear brake pads with improved noise suppression properties have been introduced in production. These improvements are now available as a service solution. If a customer should complain of a squealing noise from the front or rear brakes follow the appropriate instructions below.<br></TD></TR></TABLE><br>
In looking at the paper work, they stated that both the front and back rotors were "out of round" and were both replaced with pads. No shims installed. No mention of TNN on the work orderI couldn't find the TNN. At low speed there was a harmonic hum and then they would squeak when the brake was depressed.<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>vizwiz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Coasting, except for a couple of quick shots when releasing the clutch from a standstill.</TD></TR></TABLE><p>Does it disappear when you start accelerating or hit the brakes?<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>LA-s60r</b> »</i></TD></TR><TR><TD CLASS="quote">Get your brakes checked. I had the same problem and they replaced the rotors and pads. Noise is gone. There is a TNN.</TD></TR></TABLE><p>If you are referring to the brake squeal, this is not it.<p>This is a humming that comes about when coasting or cruising and goes away with the slightest tap of the brakes.<br>
Re: Name That Tune: My R Started Singing To Me (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Does it disappear when you start accelerating or hit the brakes?<p>If you are referring to the brake squeal, this is not it.<p>This is a humming that comes about when coasting or cruising and goes away with the slightest tap of the brakes.<br></TD></TR></TABLE><p>That describes the exact problem I was having. I approached my service department with this problem and they came up with nothing.
Re: Name That Tune: My R Started Singing To Me (05BruzaS60r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>05BruzaS60r</b> »</i></TD></TR><TR><TD CLASS="quote"><p>That describes the exact problem I was having. I approached my service department with this problem and they came up with nothing. </TD></TR></TABLE><p>Which has been the conclusion of many service departments.<p>Elak's service guy replaced the pads and rotors and he said his problem is gone. I replaced my pads with the Raybestos pads for the Cadillac CTS-V and it has been pretty quiet, but there was one occasion where I thought I might have heard a hum, but haven't confirmed it. <br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Which has been the conclusion of many service departments.<p>Elak's service guy replaced the pads and rotors and he said his problem is gone. I replaced my pads with the Raybestos pads for the Cadillac CTS-V and it has been pretty quiet, but there was one occasion where I thought I might have heard a hum, but haven't confirmed it. <br></TD></TR></TABLE><p>Better than what my service department did. I had a license plate and bracket from my previous R in the trunk and they just put that in a bag and tied it up. Issue resolved? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <p>NO
1 - 12 of 12 Posts
