1 - 20 of 20 Posts
I noticed that my heated seats/defrost buttons were not backlit in the center console, so I tore it down to replace the bulb. This is the bulb that I pulled out:
I have been looking around and can't seem to find them anywhere. Anybody know what kind of bulbs these are and where to get replacements? Thanks!
$5 my rear end.
I pay about $1.50 for these at Volvo
I have about every dash bulb but these (ran out just last week) or I would send you one
Thanks everyone! I found another good site that has them, and in multiple colors too!
http://autolumination.com/74.htm
I might order a replacement and a colored one to try it out and see if it would look good to replace them all. They are still a few bucks on that site, but I stumbled upon a thread that had links to a couple places with them for very cheap, I'll find again then post it here. So the size I need for an '04 is T5? I might measure the bulb just to double check.
Just a bit of trivial info: those are the same bulbs I found in the back of the headlight switch; I originally thought they were LEDs, but I guess I was mistaken. I'm not sure what they illuminate since the circuit board inside the switch does have LEDs for the foglight & DRL status lights. Maybe they are spares...you might want to take a look-see at them.
I was trying to find a place to tie in the dimmer for my boost gauge light (no success there).
Yeah they backlight the white parts of the buttons and stuff. Here are two other links that I found from another search:
http://www.allelectronics.com/make-a-store/item/LP-70/14V-NEO-WEDGE-BASE-LAMP/1.html
http://www.opamp-electronics.com/catalog/14v-80ma-neowedge-base-incandescent-lamp-pack-p-1191.html
Those are much cheaper. I am going to double check then order some, I might get some extras just in case there is a big difference in brightness. I may also try one or two colors from that other site and take some pics so we can see what it would look like.
The ones I that I have are T4, the base is 10mm. I just ordered 5 clear (just in case the brightness doesn't match) and 1 blue and 1 red (I figure those are the most common colors people would use). When they come I will take some pics of the installation and colors and post them. I still need to get some pics of my car up too! I've been lazy...
they are not spares, the illuminate the panel while smaller bulbs work as status lights only
Ahhh, ok. Makes sense--guess I should've figured that one out on my own. :eek:
Are these the same bulbs that go into the rear window switches? One of them seemed to have burnt out in my car.
1 - 20 of 20 Posts
