1 - 1 of 1 Posts
I had to have a few things adjusted to get rid of some noises I was hearing.<p>1) I was missing the rubber grommet that covers the hole in the firewall inside the cabin. This was causing a loud wind noise every time I stepped on the gas.<p>2) The subframe had moved from its original position slightly after the sway bar installation. This was causing some tire rub.<p>3) The bearing that supports the downpipe had to be shimmed. The downpipe was making contact with the driveline sometimes. Must have been stock bearings because the downpipe didn't come with them.<p>Anyway, it's all fixed now and I'm a happy camper. Joshua at Rempt Motor Co. did an excellent job: <A HREF="http://www.remptmotorco.com" TARGET="_blank">http://www.remptmotorco.com</A>
1 - 1 of 1 Posts
