E-bay Pedals
Installation was a lot harder than I anticipated.
Here's a simple fix-it tip if you're installing these pedals too.
Brake pedal:
1. Remove the rubber pad on the brake pedal.
2. Line it up with the new pedal and drill holes for the screws.
3. Cut away the excess rubber so the washers will fit in place.
4. Tighten all the screws (make sure not to over tighten or else you may tear the rubber pad).
5. Cut the tips off of the screws.
6. Wrestle with the pedal to get it back in place on the car.
Gas pedal notes:
The holes that you need to drill are just outside of the existing grooves in the plastic pedal. What I found to be easiest was to drill straight into the grooves, then angle the drill to widen the holes until the pedal cover would be centered on the gas pedal. If this is confusing, you'll understand what I'm talking about as you're installing your own.
The Dead pedal screws right into place.
Review:
I'm quite pleased with the quality and appearance of these pedals, especially for the cost; much cheaper than anything else on the market for our cars. The "almost Volvo font" looks identical to Volvo's font and the pedal shapes are a perfect match to the factory pedals. The rubber grips are also quite grippy and well attached.
My only complaint is that the mounting hardware was insufficient for the brake pedal and had to be modified, and the gas pedal was a slightly more curved than the stock pedals (though it was easily bent into the necessary shape).
I guess the only true negative is that the dead pedal rubber grips are not set on an even grid, they're kind of randomly spaced.
(Please ignore the dirty carpet and over exposed phone pic, I'll take a better picture after I vacuum up the drilled out scraps)
Brake pedal:
Gas pedal notes:
Review:
