MyNameIdeasWereTaken AWD C30 Progression Thread
288167 Views 865 Replies 113 Participants Last post by  MyNameIdeasWereTaken
2008 Volvo C30 T5 "Belle"
Phase 1:
V2.0 Cosmic White / Laser Blue Metallic
FWD M66​
272whp
345ftlbs of torque
0-60mph: 4.925 seconds
Phase 2:
AWD M66​
266whp
331ftlbs of torque​
Stock Options:
Bi-Xenon headlights (DRLs disabled)
Fog lights
Dynamic Stability Traction Control
Cruise Control
Rain Sensing Windshield
Brushed Aluminum Interior Trim
Power/Memory Driver Seat
Dynaudio
"Illumination"
Sport Pedals
Carbon Fiber B-Pillars
Tire Pressure Monitoring System
Sunglasses Holder
Rubber Floor Mats
Rear Bumper Reflectors
Auto-dimming Mirror with Compass
R-Design Gauges
Rear Mudflaps
Stock Options:
Fog lights
Cruise Control
R-Design Interior Trim
"Illumination"
Sport Pedals
R-Design Gauges
Rear Mudflaps
Exterior Cosmetic Modifications:
Interior Cosmetic Modifications:
Audio & Electronics:
3 Way 12V Splitter
Garmin GPS
Cobra Radar Detector
Kinivo Bluetooth Aux Unit
Glowshift Boost/Vacuum Gauge
Glowshift Volt Meter
Battery Relocation
(see more info here)
Eyourlife LED Light Bar (see more info here)
Black Box G1W Dash Cam
Quad Fog Lights
Performance & Handling:
H&R Coilovers
Elevate Rear Sway Bar
Massive Adjustable Rear Camber Arms
Forge Recirculation Valve
Elevate Turbo Control valve
IPD HD Coilpacks
Custom Short Ram Intake
Elevate Intake Plenum
Do88 Intercooler
Elevate Intercooler Hardpipe Kit
Elevate Silicone Hose Set
Elevate Non-Resonated Cat Back Exhaust
Manzo Catless 3" Downpipe
Newman Camshafts
Custom Shark Tune
Stainless Steel Brake lines
Eurosport Tuning Front Strut Bar
TheBelgian Half Cage
(see more info on rear brace here)
Meyle HD Endlinks
Mazda 3 Torque Mount with WhiteLine Kit
Greddy RS type BOV
Fumoto Oil Drain Valve
Porsche 70mm Throttle Body
Hotchkis RSB Brackets
Mishimoto Aluminum Coolant Reservoir
Wilwood 6 Piston 320mm Front Brakes
TheBelgian 320mm Rear Brakes
drjonez Race Mode switch (see more info here)
KYB Adjustable Shocks
Clutch Shock Load Limiter Delete
AWD Conversion (see a video here)
H&R Coilovers
IPD HD Coilpacks
Evolve Intercooler
Custom Non-Resonated 3" Exhaust
Custom Catless 3" Downpipe
Custom Shark Tune
Custom Rear Upper Stabilizer Bar
Honda Pilot Endlinks
Damond Torque Mount
Greddy RS type BOV
Volvo 320mm Front Brakes
Awards & Features:
561 - 580 of 866 Posts
Yeah... Just too much time and money to bother putting it on a dyno after each individual part. Especially when I'm "done" with this car and don't care to spend more on it.
Without a remap, I've heard people gaining 5-10whp with the turbine wheel upgrade. With a tune, the ST225 Focus guys are seeing 20-30whp, but my expectations are pretty low for this.
A well written aftermarket tune will definitely show better results than what you're getting with Polestar. P* adapts pretty well to upgraded parts, but it's still only designed to optimize the stock parts. Especially with the FMIC and DP, you should be holding boost around 16-18psi. The few bolt-on build P* tuned cars that I have driven were noticeably slower, you could tell they had a lot of untapped potential.
OBD Fusion says 20 psi. ;^) High ambient temperatures kills power, though. I'd kind of rather fool myself and even it out, say 17 psi at 60F ambient and 20 psi at 90F, for example. Not sure how that math works.
You cannot get an accurate boost measurement via OBDII, as the sensor is merely measuring for pressure and flow and not specific PSI. That's why people who upgrade the piping and put larger intercoolers on stock and polestar tuned cars will usually see a drop in peak boost; the car is seeing the expected airflow sooner and cutting boost off. I can hook up OBDII to measure my boost and it says I'm holding at 35psi, which a complete joke.
The only way to accurately measure boost on our cars is with a boost gauge.
Truth be told, 20psi is a dangerous boost level for a stock K04 and you might have a problem with your wastegate if that's what you're actually hitting. You might peak at 19-20psi on a good day with all the bolt ons, but 20+psi is K16 territory. The K04 just can't safely handle it.
Based on air density, if your car is consistently pushing XX.X amount of air into the engine, than warmer ambient air can actually show a higher boost level than cooler air because it is expanded and wants to fill more space. A few people have claimed they see higher peak boost in the hot summer, but this is likely due to their MAP sensors being gunked up with oil or something and not properly regulating the amount of air that gets pushed through the engine. But even if you do see a higher peak boost on a hot summer day, high boost does not mean the car is running efficiently. There's a reason why ambient temp in the 60s is considered optimal boost weather.
After months of searching, I finally scored a local deal for an upcoming project.
Runs a little rough, but it's clean and it'll make a good FWD car once I'm done. ;)
I think I know what you're up to!!
Be detailed! I’d love to have what I think you’re going for and need to know if it can be done in the driveway as I have no garage.
2007 V70R Ti Grey Nordkap GT, 2008 C30R-Design Black M66
FWD or AWD? Looks clean.
It will be FWD when Michael is done.
It's an AWD donor for making my C30 AWD. I'll put this S40 back together as a FWD car, fix a few of the things that are wrong with it, and resell it for cheap.
Right on! Knew it.
I'll start the popcorn. This will be fun to watch!
3
Back to your regular FWD updates... The teardown has begun. Low quality phone pictures and no how-to this time 'round. This is my first head gasket on a T5, so I'm learning as I go and don't want to double my job-time worried about pictures or footage. There's plenty of other good (though lacking) tutorials online. The next time I do this job, I'll do a more detailed writeup.
While parts are off, I figured I might as well paint them. It's about time I color matched some of the engine bay accents.
The crankshaft pulley bolt is super stuck. Tried every penetrating spray on the store shelves, with my impact, but no luck. So I ordered the Volvo crank holder tool. It'll be here in a few days.
But I wasn't going to let that slow me down. There's a TDC marking on the pulley. Lined it up and the crank lock tool (which fits in with the starter removed) slid right into the place. This allowed me to remove the timing belt from the VVT gears and proceed.
First hold up was getting the cam rotors off, the torx screws were slightly stripped (the previous owner posted about having issues with these as well). Broke a few bits in the process. Bought new bits, cut them down so they were square with no beveled edges, and that worked like a charm.
Everything was going smoothly until I got to the head bolts. Half of them appear to have been rounded during installation. I know the previous owner had bent 2 valves, so he would have been in here at some point... Any suggestions? There's no way to access the bolts to cut them off or drill them out, nor do I want to clean out a bunch of metal scraps.
The head bolts require an extension to get to and they take a lot of force to get off. I got 3 of the good bolts out and then broke my socket. Pelican Parts write up says they broke 2 sockets in the process.
I'm going to pick up some new sockets tomorrow, maybe try hammering a smaller socket onto the bolt, then try those stripped-bolt-removing biting sockets. But at this point, it's starting to look like an engine swap will be easier.
Luckily, I just so happen to have a couple of T5s in the driveway. I would "need" to swap over my cams since that's what my tune is written for and I'm not going backwards from the power I'm used to. But now I'm back to seriously questioning if all this work is worth it... I guess we'll see how tomorrow goes.
Forgot the pictures!
Here's the engine mount bolt that the dealer had cross threaded. Prying with a pickle fork and using an impact is what broke this off after fighting with it for two full hours.
This is where I leave off for the night...
I got some impact bolt-biting extractor sockets and finally got the rounded head bolts out.
After removing the head, I was disappointed to find the head gasket in perfect condition.
I have 3 cracked cylinders.
I know this happened back on July 13th, because my compression has always been perfect and I have never lost a drop of coolant. It likely occurred during some high-boost pulls on the local roads. I let the car idle for about 10 minutes before shutting it off, so it was not a matter of turning the car off too quickly. But it was at night, so I did not notice any smoke until the next day.
No overheating issues either... Everything suggests that this was a moment of over boost. I'm not blaming this on anyone, any parts, or the tune. It's a risk that we all take by modifying.
I also discovered that all five pistons have dents from impacting the valves. Again, my compression has been fine, so it's likely that this was remaining damage from when the previous owner bent and replaced the valves.
While I have another engine I could swap in, I am NOT putting a stock block back into my car. I have been dissatisfied with this maxed out K04 and FWD platform for a while, I had plans for the hybrid turbo and the AWD swap. But the amount of time, money, and effort to get this car back to where it previously was, is more than I’m willing to invest. Especially since I would still be facing a long to-do list to make this car something I would actually be content with it.
After thinking and praying for guidance, this is the end of my C30.
To the Volvo community, this might seem illogical when I already have the parts. But I still have the V50 for M66 AWD fun. With the seemingly constant maintenance that all my cars now require, I need something lower mileage. Plus, I'll never improve as a driver if I keep myself limited to this platform.
TL;DR
I'm going to be looking at some newer cars this week. Requirements are 250+ whp stock, RWD, manual, 2 doors, and with an engine that's actually meant for mountain runs and track days.
Do NOT message me about a part-out or call dibs on any parts.
I may sell the entire car with my spare engine, if anyone wants to rebuild it.
I may swap out some parts with the V50 and then take my time with parting it out.
I may revert it to stock-ish and replace the engine; keep it as a daily or sell it...
It could always have ended worse! It has been a fun run and even these last few days have been a great learning experience. Huge thanks to SwedeSpeed and C30Crew for the wisdom, inspiration, and friendships. :)
Here's one of three cracks...
Man, that blows! I was looking forward to another awd C30 on the road and watching the process of getting it there.
New block with the mustang T5 transmission and rwd c30
Michael! Noooooooo!!!
So sorry to read this. You have been an inspiration to so many folks on these boards. What a bummer!!
You have bailed me out more times than you know and that I can count.
Your builds and your tutorials have been fabulous. I selfishly hope you stick around in some capacity because you provide great wisdom and support.
Matt
...the dark side beckons...
