MyNameIdeasWereTaken 850 Progression Thread
68350 Views 175 Replies 28 Participants Last post by  SunroofGirl
1997 Volvo 854 GLT "Quebert"
Pewter Silver Metallic
FWD Automatic
Stock Options:
Traction Control
Cruise Control
Sunroof
Leather/Cloth Interior
Wood Grain Interior Panels
Side Impact Protection System (SIPS)
Premium Sound System
Power/Memory Front Seats
Built-in Child Seat
Exterior Cosmetic Modifications:
Interior Cosmetic Modifications:
Audio & Electronics:
Performance & Handling:
iPd upper engine mount
5mm rear H&R spacers
Polyurethane torque mount
101 - 120 of 176 Posts
Can you please take a closer picture of the coolant reservoir?
No
Finally got around to installing the new coolant tank and flushing the system.
That's funny, I did the same just recently. Did you also take advantage of IPDs June sale? I went ahead and did ALL of the coolant lines, tank, and Tstat. Altogether it was only like $75 after their sale. I bought the turbo supply hose but did not replace it due to location. What a PITA to try and get to.
No, shipping wasn't worth it for just the tank. I bought a new tank on ebay for $20 shipped. :D
It's a very nice high definition photo of just a tank. Probably the most professional photo of just a coolant bottle ever taken lol
Long time no post... any progress on the project?
Going to be doing brakes soon. May as well paint the calipers while I'm in there. What paint did you use? link?
Nothing other than maintenance as of recently... I still have a pillar pod and boost gauge to install when I get the free time.
I took the S40 to Stage 3 and have been focusing a lot on that recently.
I bought a silver caliper spray paint from the autopart store. Cleaned the calipers really well, then painted it on as a base coat. I used a regular Rustoeum purple spray paint for the top coat. Then a high temp clear. It has held up great so far! No chips, bubbles, or flaking, and the smooth surface cleans very easily. I still need to apply the Volvo decals, so thanks for the reminder!
I used the same silver paint on the S40, with no top color. It has held up for 3 years now.
Surprising regular rustoleum held up. Being the midcoat doesn't really matter, it still feels the heat. I was going to get some VHT spray from amazon. What high temp clear was it? Where are you getting your Volvo vinyl decals from?
The Rustoleum can said paint could withstand up to 300°F, so I figured it'd be safe enough on calipers. Turns out it works!
The clear was a high gloss engine bay paint, also from the autopart store.
Here's the caliper decals, I've had them on the S40 for 3 years with no issues at all. I got metallic silver for the purple calipers.
http://www.ebay.com/itm/Volvo-Brake..._Merchandise&var=&hash=item43b0ce28e9&vxp=mtr
I noticed you painted the back of the brake pads as well. I plan to do the same. Hope it doesn't look bad after the next pad change.
Yeah, I figured I'd paint it all for now. I've since changed out the pads on the S40 and it actually looks a little cleaner (they're black backed pads).
Does anyone know the exact specs of the factory GLT turbo IC? Would fitting a stock P1 IC give any benefits at all?
Walked Bailey through a horn relocation project tonight. Really cleans up the grille area, I'll post pictures once Google decides to come back up...
I'm excite to see what you did. The previous owner also somehow cracked the horns on mine so they look pretty awful.
This is bullsh*t. I was promised pics.
Pics are coming! I'll try to upload them on my lunch break today.
2
I disconnected the wire harnesses to the horns, then removed 3 clips which were holding the wires in place in front of the radiator. I pulled the wires back towards their source point, which left me with about 3 feet of slack near the battery. The wires for both horns were bound together, so I separated them for each horn individually. You can see where I mounted both horns, the wire for the close horn (by the battery) was easy to connect, the wire for the far horn was strung along side the hood release cable.
Very nice, I plan on doing this also. But you forgot the most important pic, how clean does it look with the hood closed?
I might be getting an iPd mesh grille from a friend, so I'll share a picture then. ;)
I'll take a pic of how it looks now, but you can't really tell a difference through the waterfall grille.
Installed a boost gauge, easiest job ever! I had no idea about the "vacuum tree," easy access pass through in the fire wall. Pics to come once we finish the pod.
